Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-14-2006, 11:14 AM   #1
Brett Richmond
CF Senior Member
Brett Richmond's Avatar
Default Diacom???'s
I have not used Diacom in a good while, I have a no start problem going on with my 89. Already replaced the fuel pump,plugs, and fuel filter, now there is a problem with one or more injectors as to leaking. Next on list is to replace them. I am trying to see if Diacom will help out with checking anything else that might cause this problem. The car will start if I spray starter fluid into the TB but it runs horrible this way but it stays running. Any ideas would be helpful..
TIA
Brett
__________________
'89 BLK/BLK
Corvette Challenge Registry
Morrison Race Car Registry
Brett Richmond is offline   Reply With Quote
Old 10-15-2006, 09:54 AM   #2
Casethecorvetteman
CF Senior Member
Casethecorvetteman's Avatar
Send a message via MSN to Casethecorvetteman Send a message via Yahoo to Casethecorvetteman Send a message via Skype™ to Casethecorvetteman
Coil, ignition module, distributor cap, rotor, and the carbon contact. Check all that if you havent allready
Casethecorvetteman is offline   Reply With Quote
Old 10-16-2006, 09:17 PM   #3
Brett Richmond
CF Senior Member
Quote:
All have already been replaced. I just find it hard to believe the injectors alone could cause this?
__________________
'89 BLK/BLK
Old 10-16-2006, 10:25 PM   #4
Sam Lam
CF Senior Member
Sam Lam's Avatar
Brett: Check you injectors (remove harness connector) with an ohm meter. All injectors should be very close to the same reading and be somewhere in the 16 to 17 ohms. Check 'em cold and hot ..... if the engine will run that long The 89 model seems to have a lot of injector issues with the stock units. The coils short out and this will not place a fault in your ECM. I learned all this the hard way on my 89.
Sam Lam is offline   Reply With Quote
Old 10-19-2006, 09:17 PM   #5
golfpro77
CF Member
golfpro77's Avatar
If your injectors are leaking, it will flod the engine... my 90 had this problem and had to wait about 45 minutes if it did not start right away... it also back fired when decelerating. Issue was resolved after injectors were replaced.
Might not be yor problem but it will act like a flooding situation if they are leakign bad.. but should eventually start.
golfpro77 is offline   Reply With Quote
Old 11-18-2006, 11:06 AM   #6
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
It seems to me that if the car will run with starting fluid that your ignition may be fine. You also say that you replaced the fuel filter/pump, but do you know what your fuel pressure is? Is the pump running? If the pump isn't running or you don't build pressure with the key on, then maybe it is your fuel pump relay or ECU. Just another thought. Good luck!
__________________
91 (383 LT1 turbo, under construction)
92 (Heads, Cam, Exhaust)
ANTI VENOM is offline   Reply With Quote
Reload this Page Diacom???'s
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
30# injecters were too BIG for my 383. Are 22# too small? B84RADR C4 Tech/Performance 111 02-21-2004 05:13 PM
Strange Diacom Timing Numbers JAKE C4 Scan & Tune 14 12-24-2003 02:18 PM
Guess the results of tomorrow's injector test! Nathan Plemons C4 Tech/Performance 46 11-08-2002 09:59 PM
Got any room for another member in the 12's club? scorp508 C4 Tech/Performance 61 06-03-2002 02:24 AM
Let's see where everyone is HighHopes85 C4 Scan & Tune 28 04-11-2002 02:17 AM
I have one of the weaker LT-5s, dyno #s within. FastZR1 C4 ZR-1 Discussion 29 01-23-2002 03:59 AM
DIACOM users, how did you get the disk to load to the Hard Drive, and where is you directory? steve40th C4 Tech/Performance 10 01-05-2002 05:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
