Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2006, 09:59 PM   #1
fc_soldier
CF Senior Member
fc_soldier's Avatar
Default Tunercat
If I get the tunercat software, what do I have to get to make it work with a 96 LT1. Do I need the WinFlash?
Where so I get the cable? Can I make from Radioshack stuff and what not?
fc_soldier is offline   Reply With Quote
Old 10-13-2006, 06:57 AM   #2
Casethecorvetteman
CF Senior Member
Casethecorvetteman's Avatar
Send a message via MSN to Casethecorvetteman Send a message via Yahoo to Casethecorvetteman Send a message via Skype™ to Casethecorvetteman
Have a look at this thread here for cable making process and diagrams, but i dont know if it will work on a 96, they are OBD2.
http://forums.corvetteforum.com/show....php?t=1381422
So also have a look here:http://www.obd2allinone.com/
No you dont need winflash with Tuner Cat. BUT you have to make sure you have the right version of Tuner Cat and i havent seen one for a 96 yet.
Casethecorvetteman is offline   Reply With Quote
Old 10-13-2006, 11:55 AM   #3
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
I'm pretty sure with your 96 (OBDII), you'll need to get Tunercat's cable. Shoot them an email with any questions. Usually they are quick to respond.
-Mike
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 10-13-2006, 12:13 PM   #4
fc_soldier
CF Senior Member
fc_soldier's Avatar
THX
Old 10-14-2006, 12:09 PM   #5
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
To make tunercat work with a 96 you would need a new ECM.
He had OBD2 software but sold it to Jet.
Start here:
http://forums.corvetteforum.com/c4-scan-and-tune/202488-corvette-forum-ecm-pcm-tuning-section-faq.html
Vis Croceus is offline   Reply With Quote
Old 10-14-2006, 03:18 PM   #6
STL94LT1
CF Senior Member
STL94LT1's Avatar
Start here:
http://forums.corvetteforum.com/showthread.php?t=202488
Hmmmm, didn't know that.
__________________
2006 Cobalt LS (DD)
Old 10-14-2006, 03:28 PM   #7
fc_soldier
CF Senior Member
fc_soldier's Avatar
Start here:
That forum is to crazy and all over the place to make sense of a 96 corvette ecm. All it talks about is every year but 96 basically.
Alot of us look for clarity on the 96 issue.
THX
Old 10-14-2006, 05:42 PM   #8
Vis Croceus
CF Senior Member
THX
There is plenty of easily-found information on the net for tuning these cars, all you have to do is search and read. If you can't be bothered to even wade through the FAQ, you aren't going to be very successful with tuning.
Old 10-14-2006, 07:09 PM   #9
fc_soldier
CF Senior Member
fc_soldier's Avatar
If you try looking for it you hit tons of dead ends! Ive been searching for a couple of days now but 96 seems to be the exception year.
95 stopped the standard burning process then 97 they got the LS1s so 96 is stuck in the middle.
Im new to the game I was hoping some could say I found a site the really helps. The forum stated is useless to a 96. Im willing ready but all I find is the same stuff everyone else is saying.
Old 10-14-2006, 08:15 PM   #10
STL94LT1
CF Senior Member
STL94LT1's Avatar
The 96 PCM flash tunes just like the 94/95 versions. Only difference, GM went to OBDII in 96.
http://carputing.tripod.com/9697lt1edit.htm
__________________
2006 Cobalt LS (DD)
Old 10-14-2006, 09:42 PM   #11
fc_soldier
CF Senior Member
fc_soldier's Avatar
Thanks simple and to the point.
THX
Old 10-15-2006, 02:51 AM   #12
Vis Croceus
CF Senior Member
96 and 97 LT1s are identical.
Old 10-15-2006, 10:34 AM   #13
fc_soldier
CF Senior Member
fc_soldier's Avatar
Well as for the corvettes they stopped the lt1 in 1996 right? And fbody continued it til 1997. But I can use the programmers for a fbody on a corvette? Why would they be seperate if they are the same thing?
Old 10-15-2006, 10:55 AM   #14
Casethecorvetteman
CF Senior Member
Use LT1edit for the OBD2 cars. Im not sure if you can simply take the 96 ECM out and whack in a 95 ECM, but if you can do that, then you could use the $EE definition with Tuner Cat and use a regular 2 transistor type ALDL cable. Id imagine it would all work, but then again it may not. Someone will know.
Old 10-15-2006, 12:45 PM   #15
fc_soldier
CF Senior Member
fc_soldier's Avatar
Yeah Ill probly go with that one if anything!
Reload this Page Tunercat
Tags
cable, obd2, tunercat, winflash
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
New to tunercat, need $EE definition johnno! C4 Scan & Tune 9 08-15-2005 06:22 AM
OBDII Tunercat for '96 Vettes ShaneL C4 Scan & Tune 22 06-28-2005 08:52 AM
Tunercat vs Tunerpro RT LD85 C4 Scan & Tune 12 04-07-2005 07:49 PM
Concerned about what I see in Tunercat Scott94C4 C4 Scan & Tune 14 01-06-2005 09:11 AM
Unusual experience dialing a car in.. Any Tunercat folks out there? The Lurker C4 ZR-1 Discussion 18 08-23-2003 02:29 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
