My 95 has OBD1 software and some OBD2 codes according to the service manual. I have a 16 pin connector, and can pull codes grounding pin 12 ( 12 to 5 ). I have read that it very hard to find the TECH 1 the manual uses. I have read the links post above but do not see much on the 95. I would like to try LT1edit but the link don't work for me. Does anyone have software that acts like the TECH 1?
But i dont know that it really does as much as a TECH 1 unit can do, in many cases its probably better, but there is a couple things it wont do that the TECH 1 can.
I use datamaster for logging, tunerpro for programming and editing, and a tech-1 to service the car when it's down. As far as I know there is not one tool for all 3. The Tech-1 does things like reset idle and reprogram CCM's, etc that I don't belive can be done with any other software/PC combo.
I use Tunerpro RT for datalogging and tunercat to make changes to the calibration and flash that particular PCM. Are there items that the Tech1 allows changing that tunercat does not?
