Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-12-2006, 11:28 AM   #1
93 ragtop
CF Senior Member
93 ragtop's Avatar
Default Chip addressing ?
I have a Moates burn 1 using software v1.02
Can someone tell me what the chip addressing and buffer addressing should be, start and end address? Thanks for your help
Edit to add the chip is a at29c256
__________________
93 Automatic White Vert. 4.09 gears, Yank 3000 converter, Hot Cam, ported heads, Exotic Muscle LT headers, magnaflow mufflers Meziere water pump, and professionally tuned by Alvin and it passes emissions!!
My best run 11.82 ET at 116.52 mph. and 1.66 60ft.
My wifes best run 11.71 at 117.31 mph.
362 rwhp
379 torque
93 6 speed White Vert. 383 with a rear mount 85mm turbo. water to air intercooler, 6 pt. rollbar. Gen. 7 dfi. and many more extras. No numbers yet!!
93 ragtop is offline   Reply With Quote
Old 10-12-2006, 05:22 PM   #2
goldeneye_vet
CF Senior Member
goldeneye_vet's Avatar
http://www.moates.net/documentation....entation_id=20
__________________
1985 383 superram, TPIS Big Mouth intake, 52mm BBK TB, RHS 210cc alum. heads, 224/230 custom grind comp roller cam .503 intake and .510 exhaust, 1.5 comp pro magnum RR, 24# FMS injectors, AFPR, descreened MAF, Hedman Elite headers, dynomax mufflers, ATI 2600RPM TC, camber brace, poly bushings, 9.5" Y2K aluminum rims on 285/35/18 sumitomo tires, Edelbrock IAS shocks, Big Mouth Air Dam.
2000 Millenium Yellow vette.
goldeneye_vet is offline   Reply With Quote
Old 10-13-2006, 07:51 AM   #3
93 ragtop
CF Senior Member
93 ragtop's Avatar
Thanks for the link!! I used the correct settings and it now works again.
Reload this Page Chip addressing ?
Tags
addressing, chip
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Burn ! success steve40th C4 Scan & Tune 10 08-26-2005 02:42 AM
Where do you guys set your base ignition timing (L98)? TheCorvetteKid C4 Tech/Performance 61 08-21-2005 02:17 PM
160 Thermostat JIMVET C4 Tech/Performance 40 06-13-2005 08:49 AM
C6 Black Box Revisited 4CEE C6 Corvette General Discussion 30 04-15-2005 03:06 AM
mailorder chips unlocked kvu C4 Scan & Tune 112 04-14-2005 09:59 PM
Freaking expensive $$$$$$ Bruce C4 Forced Induction/Nitrous 13 04-02-2005 01:47 PM
Aftermarket/ Custom Chips James93LT1 C4 Tech/Performance 76 01-01-2005 01:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
