Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit Sponsored by
Ultrarev
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2006, 12:15 PM   #1
RRT vette
CF Senior Member
RRT vette's Avatar
Default Which laptop do I need to use TunerPro RT or Datamaster?
I am in the market for a scan of my 86. I can't seem to find anyone around my area that will do a complete scan and I would have to trailer the vette due to running condition. I have decided to go with a laptop setup to probably run the TunerPro RT software. I just found out that Craig Moates lives about 2 hr away and I am interested in getting up with him. I know on C4 Scan and Tune it will take a while for info, due to not much traffic here. My question is what Laptop or equipment will I need to run the TunerPro RT. Do I need windows 2000, USB hookup, lots of MHz and GB, or just what? The more info the better...I know you guys are out there. I also have a 95 which uses a ODB2 cable for the OBD1 system that I would like to scan in the future. I will probably get the two different cables from Craig. Thanks
RRT vette is offline   Reply With Quote
Old 06-01-2006, 12:39 PM   #2
Casethecorvetteman
CF Senior Member
Casethecorvetteman's Avatar
Send a message via MSN to Casethecorvetteman Send a message via Yahoo to Casethecorvetteman Send a message via Skype™ to Casethecorvetteman
I have an ASUS L2B, its a very grunty laptop for the job, all you really need is about 400Mhz, 256MB ram, and id go with Windows XP. a proper Serial port is a very desired item. you wont need 2 different cables, the 86 will probably run in 8192 BAUD data, the only advantage to the OBD2 plug on your 95 is the fact it can suply power for the cable. Requirements are less than i have stated, but this is what id go for, and forget USB if you can avoid it.
Casethecorvetteman is offline   Reply With Quote
Old 06-01-2006, 02:19 PM   #3
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
You can use just about any old WIN98 or XP PC that has a 9 pin serial port. It does not require great computing power. Any old but decent 486 would work fine up to the pentium class PC's.
tjwong is offline   Reply With Quote
Old 06-01-2006, 02:47 PM   #4
RRT vette
CF Senior Member
RRT vette's Avatar
Thanks guys, will one like this one work for me? If not do you see one that will? One in the $150-175 price range or can they be had? I am mainly using it to scan my vette and really nothing else. I don't have a real use for a expensive laptop, so that's why my price is.
http://cgi.ebay.com/DELL-LATITUDE-C6...QQcmdZViewItem
Old 06-01-2006, 05:09 PM   #5
rick lambert
CF Senior Member
rick lambert's Avatar
If you use Moates..you will need both cables for your 86. That computer is to expensive in my mind. I'm using and old Toshiba 490 CDT Satelite Pro with windows 2000, has the right serial port and a USB port required for Moates. The computer cost less than $100. including shipping, and they're plentiful on ebay.You can email Craig to confirm 2 cables, I did and that's what he said. Thought you were on vacation!
rick lambert is offline   Reply With Quote
Old 06-01-2006, 05:20 PM   #6
RRT vette
CF Senior Member
RRT vette's Avatar
Quote:
I see Rick, there are a lot of Toshiba laptops on there and for cheaper. I haven't contacted Craig yet but will in the near future. I'm trying to sneak this behind my wifes back. I leave on June 4th, on my way to Destin, Fl. Have to work today and tomorrow and a wedding to attend Sat. I will took into these laptops a little more. Thanks
Old 06-01-2006, 08:35 PM   #7
steve40th
CF Senior Member
St. Jude Donor '03 & '05
I use a COMPAQ 3 GHZ processor blah blah laptop. The only problem I have with the AKS cable and TTS is it actually linking up with the car, 1993 Vette.
steve40th is offline   Reply With Quote
Old 06-02-2006, 04:29 AM   #8
Ray Quayle
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Ray Quayle's Avatar
DJ, Please keep us posted if you go with the Moates and TunerPro as I'd really like to know if you can get 8192 data with your $32 '86 mask from TunerPro.
Ray Quayle is offline   Reply With Quote
Old 06-02-2006, 08:03 AM   #9
Casethecorvetteman
CF Senior Member
Quote:
Are you trying to say here that it wont work properly with DataMaster?
Old 06-02-2006, 12:21 PM   #10
steve40th
CF Senior Member
Quote:
Its intermittent, sometimes it links right up, sometimes it just waits forever and then POOF it connects or not at all. I am sure there is a settings issue, as with DIACOM I needed to even slow down the 486 laptop I had to work right.
Old 06-02-2006, 12:25 PM   #11
Casethecorvetteman
CF Senior Member
Is it practicle to try connecting it to your desktop PC serial port? If so try that and see what you get.
Old 06-02-2006, 12:29 PM   #12
steve40th
CF Senior Member
It wouldnt be practical, as the computer desktop is on the other side of the house. My other laptop, once I get it back, has a serial port. I havent heard much luck with serial to USB conversions, but it did work, and does sometimes.
Reload this Page Which laptop do I need to use TunerPro RT or Datamaster?
Tags
datamaster, equipment, tunerpro, user, vs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
