Desperatly need the pinout to the 9278 (93)lt1 Ecm
I desperatly need the pinouts to the 93 lt1 ecm. Bruce's car went brain dead on us last night while idling in my shop. Now I get no spark/tach/fp etc. But before we go buy an ecm I need to check the basics 12v/grnd etc. Can anyone help? even post just the nessary ones, 12v in tach out anything power on related etc.
I have it but it is in Charles Probst "Corvette Fuel injection book, so there could be a few minor mistakes. when I wired the LT1 I put in my 84 the only mistake I found for the 94/95 wiring was the fan relay set up but what they had worked. Is there a particular section you need?
Any page concerning what the pinout for the ecm itself are. The car doesn't turn on anything. No pump, no delteq, no tach. No nothing. I have used a testlight on the connectors with the ecm unplugged and have found juice/ground on many pins, but have no idea where they go. Before we spend $$$$ on an ecm I need to confirm she's dead.
Maybe this can help- 90-91 ECM closest I could find
http://chevythunder.com/fuel%20injec...%20pinouts.htm
According to this page its a very similar ECM pinout
Good luck man. Hope you figure it out
The 1992-93 model years use ecm # 16159278. It is similar to the 1990-91 Corvette weatherpak ecm. The connectors plug in the same way. The 1992-93 LT1 engines are MAP systems with batched fire injection. It also has a removable prom chip. The later years do not.
well it had some good info, I just ruled out the grounds for the ecm, sensor grounds and the battery feeds. I still need to find out the rest (if any ) of the wires. This thing really has me stumped, but I am flying blind at this point. Still no phone call from the machine shop, John. I hope he calls me by five or we'll be stuck until monday.
Hopefully he'll call, if not thanks for trying.
fixed, It was a broken wire inside the insulator in the main engine harness. ISpecial thaks to john for lending me the oscilliscope, I would have never found the internittent connection without a graphical display. Thanky sooo much. Bruce, you owe that man a beer or 12.
The 12 volt feed (pink with a black stripe) I could get it to run, then not, then arm the pump, then nothing. so I went thru the harness where ever there were power feeds and observed the signal coming from the wire. The offending wire had a "blip" followed by a dead signal depending on how hard I yarned the harness. after it that it was a matter of chasing the wire down until I found the soft stretch part in the wire. Cut resolder. 3 days of hassle over a wire in the back of the harness. Be nice to your harness when you swap motors.
should the c12 pin be 12v. mine shows to be grounded through the pcm. car wont start no injector pulse or spark. if i apply 12 volts the car will start but wont stay running
