When looking at the differences between apyp and my bin programmed by another person a while back I noticed a few major differences.
When looking at the Minimum % TPS to enable PE mode I see the stock chip is 70 % where my chip is 30 %. What would the difference be if no changes were made at all in this field?
and
in the apyp under PE vs. RPM I notice a lot of negative values (-7.82) where mine reads anywhere from 60.15 @ 2000 RPM to 6.25 at 6400 rpm. Does this seem normal and/or what would be the major difference in engine performance if no changes were made at all?
Basically I'm trying to understand these changes and why they are made.
__________________ 1989 super rammed 383 stroker No dyno runs or track times on the new motor yet 150 hp TNT nitrous ready and hoping not to twist any more half shafts!!
The minimum TPS to enable PE mode makes the car go into its PE mode sooner. PE mode has extra enrichment. Its designed to knock the car from 14.7 type stuff down to 12-13.0 stuff.
It also forgets about most feedback from the o2 sensors.
The PE changes he did he likely did on the dyno. You can change those values to anything to make the desired AFR come out on the dyno. You can't nessisarly guess what the AFR is going to be by those PE numbers.. it is only a desired, which is quite different from actual.
I don't have highway mode spark advance in my definition, but my factory PE spark advance was:
Power Enrichment Mode Spark Advance
RPM Degrees
4800 1.05
3200 9.14
2000 1.05
1200 1.05
400 0.00
When scanning I was getting significant spark retard above 2800 RPM, I adjusted this table down to 1.05 @ 3200 so my PE Spark Advance table is now flat. My factory main spark table is pretty aggressive too, I have taken timing out in some cells there as well to lower my spark retard to only a few degree's instead of the double digits I was getting.
Not sure why OEM settings are the way they are, but I don't see any benefit to be running my timing off the ESC module, which is basically what is happening when the PROM setting is commanding "more timing" and at the same time the ESC module is commanding "take timing away".
The ESC doesn't do anything with timing unless the ECM tells it to...were you getting high knock counts?
The PROM's spark tables are a "base" for it to work with, adding spark or subtracting it as needed..ie PE mode, knock, coolant temp, etc.
I'd look into why you were getting spark knock at that point. If it was just too much timing, I would adjust the main spark tables , not the PE spark.
That is what I did, but if I left the PE spark table alone I still got more timing retard @ 3000 RPMthan I really wanted. I only had to adjust the high LV8 vs RPM cells since that is where you are in PE anyway. I mean when am I going to be turning 3600 RPM and a Load over 160 and not be in PE? Cruising down the highway at 130 MPH maybe, but I don't live in Montana so thats never going to happen, for me anyway
Still doesn't seem right that you are having to pull so much timing out of the tables. Did the programmer you used alter the tables? Adding more timing?
I'm running the ARAP .bin (about the most agressive timing tables GM made) and have a MAX of 3 knock counts (self test). Hell, I was thinking of adding to the tables, or at least to LV8.
Don't you guys hate that PE spark adder? You can actually see the dip in the spark table where they shoot in 9 degrees in some cars. I just did a car today with 9 degrees at 3200 RPM.. you can see timing rising up to about 2500rpm, a sharp dip, then rising back at 3500 or so..
It makes more since to me to do all the spark in one table.. How often are you going to be at those load values and not be in PE...
Stuiped GM..
Some of the vettes have been able to pick up a little with less timing than the factory puts in them. I think any time you ride the knock sensor your setting yourself up for it to overcorrect.
Maybe not overcorrect, but the ESC decay rates could really hurt performance by being on the edge of the knock retard...Just a few pings and out comes 11* and it takes its time about letting it back in, unless you want to play with that table too.
Just did a little calculation on my bin, under "normal" conditions I could be running up to 54.2* of timing. I'm going to have to look over some of my scan logs and see if I ever hit that number (or more)
I would consider it overcorrecting.. Do you really think your off by 11 degrees in your example..
Also, becareful in what you think the timing is based on what is in the tables. I have verified they are BS with a timing light on the dyno. Same thing with reported advance in a scan tool.. I think the best way to tune SA is on the dyno. You can manipulate timing a different poingts to find the best area under the curve.
11* was an outtathebutt number, it "can" pull in the 20's according to the table. But, like I said, I'm only getting 3 knock counts with ARAP, so I've never actually seen mine pull any timing.
Not to sound crass..but if the timing isn't coming from the tables contained in the .bin, where is it coming from?
I believe that the "reported advance" seen in a scanner is just where it is at on the base map and isn't taking into account the other tables that contribute to the "real" timing that is being run. Then again, like I said, I'm going to have a look at my logs to see where I'm at/when. Never looked at them very hard since I wasn't having a knock problem.
We where concerned that we where putting to little timing in a car so we checked the timing with a timing light during a pull. The timing averaged about 10 degrees higher or lower (can't remeber) than what the scan tool reported and what was in the table. My point is don't get hung up on a number. give the car what it likes and thats it.
My bin is the ACKY broadcast, it's main spark table is very agressive as well. I did not have to take too much out of the main table, between 2 and 6 in certain cells.
Yep, same double hump curve in my case. I researched some other bins and saw one with only 4 degree's add in PE, but at the 2000 and 3200 RPM levels, played with both tables a ton before I found my best set-up and that was to just make my PE flat and tweak the main table.
I also upgraded my ESC module per one of the tech tips, it did help lower my ESC OUT, I posted a comparison a while back.
The $8D has a 42 deg limitation (address 8026h) and add 6 deg initial timing and you arrive at 48 deg. Max SA in my logs are 47.1. Parhaps you don't run the $8D code? What is your max then?
By the way, I think the scaling in the anht_hac is wrong for this limit. It says 39 deg but that does not appear to be the case if you look at the assembly code. And 39+6 is less than 47.1, not much of a limitation then
I'm running $6E, ARAP .bin. The Max advance is 41.84* according to the info on the .bin. I'm not sure if all of the sub tables for advance get figured into the max or not, going to have to check it out.
