Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-04-2005, 11:52 PM   #1
nitrocharger
CF Senior Member
Send a message via AIM to nitrocharger
Default Injector/rich condition help
I have been fighting a rich burn condition on my TPI ever since I converted it over (its a C3). The TPI apparently is out of a 88 Trans Am and I have no idea what size injectors it has. The engine runs very rich and the computer can never seem to correct itself, although I have seen a few isolated cases where it actually works. All the sensors have been tested and/or replaced and the engine is a ZZ2 crate engine. The last thing I can think about trying is putting new injectors in as perhaps the injectors are clogged thus preventing the fuel from atomizing? Any help is appreciated!
PS, I have turned the fuel pressure down to 32 PSI
nitrocharger is offline   Reply With Quote
Old 08-05-2005, 05:51 AM   #2
Morley
CF Senior Member
Morley's Avatar
Well, you really need to know what size injectors you have in there AND, open the little cover on the ECM and look at the silver tag on the prom chip on the memcal, You'll have to take the memcal out and remove the blue plastic cover, what is the 3 or 4 letter code on the silver sticker?
Morley is offline   Reply With Quote
Old 08-05-2005, 03:17 PM   #3
DOCTOR J
CF Senior Member
Quote:
Seems like you may need to recap the basics:
Do you have datalog readings from the ALDL port?
Are all the sensor signals in range? In particular the TPS, CTS, MAF, O2, RPM and
VSS signals?
All the wiring, connectors and grounds checked for continuity? Check the intake for
vacuum leaks?
I didn't notice what you have for a trans - is the VSS output from the trans compatible
with the ECM (in terms of ppm)?
Checked for leaking injectors/fuel press regulator? Adequate size on the fuel return
line?
Could be lots of things on a conversion - solving the riddle needs a little more info on
what's already been looked at. Fella here recently posted quite a bit of detail on a
TPI project. Might be worth reviewing his experiences:
http://www.edgesz28.com/edgesZ28/sub...urban-home.htm
Good luck.
DOCTOR J is offline   Reply With Quote
Old 08-06-2005, 12:25 PM   #4
nitrocharger
CF Senior Member
The car has a 5 spd Tremec so the VSS is not hooked up. I did a leak down test and the pressure drops to 0 in about 30 minutes. I was told it should take several hours for pressure to drop?
Old 08-07-2005, 10:19 PM   #5
nitrocharger
CF Senior Member
Ok the PROM ID is 2341. I hooked up the ECM to a scanner and at idle the injector pulsewidth is 1.2 ms and the MAF is reading 9 grams/sec of air. Does anything sound abnormal here?
Old 08-08-2005, 03:31 AM   #6
Morley
CF Senior Member
Morley's Avatar
We need BLM's and O2 voltages to start.
The PROM ID you gave isn't the one I'm looking for, it should be a 3 or 4 Letter code, not number, you can't get it off the scanner, you need to get it off the silver sticker on the chip.
Old 08-08-2005, 06:57 PM   #7
nitrocharger
CF Senior Member
Akfr
2188
Old 08-08-2005, 09:25 PM   #8
Morley
CF Senior Member
Morley's Avatar
AKFR=1988 F body with a 5.0L (305)
So, if you have 22# injectors for a 350 in there, the PROM is programmed for 19#...you are dumping waaayyy too much gas in the engine.
You need to either get the calpack for a 1988 5.7L or get 19# injectors OR, get a chip burned for whatever size injectors you do have.
Can you get a part # off any of the injectors?
Reload this Page Injector/rich condition help
Tags
condition, rich, tpi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rough running, new injectors didnt help, OMG Please HELP Iroc C4 Tech/Performance 19 05-30-2004 08:19 PM
L98 TPI MISFIRES, now will NOT Start! - - > PLEASE HELP! Need to use this car! billwineberg C4 Tech/Performance 72 05-10-2004 07:08 PM
NEED HELP....1990 WILL NOT RUN... XtremeVette C4 Tech/Performance 39 04-30-2004 02:03 PM
Need Help with Cold Start Injector, and Temp sensor! RED-85-Z51 C4 Tech/Performance 20 04-05-2004 05:54 AM
HELP - Closed loop cutout/stubbling ericcer C4 Tech/Performance 55 12-08-2002 01:34 PM
Help!!!.... I'm in PCM Hell!!! wicked96 C4 Scan & Tune 9 08-15-2002 10:03 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
