Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-04-2005, 07:32 AM   #1
vtwin
Junior Member
Default Aussie Vette
Hello there my name is Dale & i live in Australia i have an 85 which i have done a factory like mirror image right hand drive conversion,and a ground up restoration to show quaility.
I have experienced intermitten problems with the service engine soon light on and off while driving.
After grounding the a & b pins on the aldl link no codes stored any ideas would be greatly appreciated.
P.s I"ll up load some pics once i know how
Thanks Dale
vtwin is offline   Reply With Quote
Old 08-04-2005, 12:07 PM   #2
msslp04
CF Senior Member
St. Jude Donor '11
Support Corvetteforum!
msslp04's Avatar
When the SES light comes on, does it run rough?? I had a similar problem but my 89 would run rough and stall when trying to idle and had no code. It also smelled like it was running rich. Mine ended up being the ECM.
Kevin
msslp04 is offline   Reply With Quote
Old 08-06-2005, 08:01 AM   #3
rons85
CF Senior Member
rons85's Avatar
There are several codes on an '85 that will turn the SES light on but not affect driveability (not send the thing into Limp-in mode). Knock signal, EGR code, etc. With no codes Stored it's more of a head scratcher.... if I remember right I had a problem a few years ago (when I first got this car) with the connector to the MAT sensor under the intake plenum - the lock tab was broken and the plug would fall out of the sensor. This would turn the SES on intermittently (not All the time) but not set a trouble code...
rons85 is offline   Reply With Quote
Old 08-07-2005, 05:33 AM   #4
vtwin
Junior Member
with this 85 i did a full engine rebuild & i checked all sensor conections they were all ok but i found 2 suspect relays witch i replaced... the last problem i had was code 32 EGR witch is not now registering that code but the idle is up at 850 then down to 500..... very annoying
Reload this Page Aussie Vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Aussie screw type blowers for LS1's Formula C5 Forced Induction/Nitrous 38 02-10-2004 05:57 AM
Aussie car tops 1206 RWHP Brutus C3 Tech/Performance 50 01-08-2003 11:24 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
