Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-02-2005, 08:49 PM   #1
Kinkajou
CF Senior Member
Kinkajou's Avatar
Default DELTEQ users please help!
I finally installed the Delteq kit in my 94 vette.
Evereything went smothly until removing the sparkplug wires.
Once done everything else was just work.
I started the car and it did not take long to come alive!
Then the idle became very erratic and when y depressed the accelerator the tach needle would go down or erratic, and the engine would sound as if it was working on less than 8 cylinders!
Then it would recover for a while ( seconds ), just to repeat the cycle, almost shutting down.
I have double checked instalation and have really no clue on this one. Before installing the Delteq I tested the system using a riveted rotor and Idled perfectly .
So Far no trouble codes are present so I assume that the optispark is working ok.
Any thought / suggestions on this will be great, thanks.
I am desperate and want to drive the vette!
Kinkajou is offline   Reply With Quote
Old 08-02-2005, 11:46 PM   #2
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
Call those guys up, I've had people have problems with thier delteq and the guys over there seem to be happy to correct or fix anything wrong with the unit.
Alvin is offline   Reply With Quote
Old 08-03-2005, 12:19 AM   #3
FD2BLK
CF Senior Member
FD2BLK's Avatar
You need to remove the tach filter. I was one of the first to install the Delteq on the 94 and after talking to Pete at Delteq I removed the tach filter and all was well. I cut the filter out then soldered the leads back togeather, it took all of 5 min. I thought they where going to add this step into the instructions, take a look it should be in there.
I found the install instructions on line and they need to be corected. They have the note about the Tach filter but they state it is for 93 only, that is incorrect. The 94, Corvette at least, also needs the tach filter removed/By-Passed. Here is a link to the instructions in case you dont have them
http://www.delteq.com/Manual_r3.pdf
FD2BLK is offline   Reply With Quote
Old 08-06-2005, 02:19 AM   #4
95Purple
CF Senior Member
95Purple's Avatar
Send a message via AIM to 95Purple
Also make sure your plug wires are the correct firing order. I had the same problem and it was to wires mixed up.
95Purple is offline   Reply With Quote
Old 08-07-2005, 12:45 AM   #5
Kinkajou
CF Senior Member
Kinkajou's Avatar
Thanks, double checked all that, tach filter was removed and white wires soldered.
It seems that 94 present different ways of interpreting data from the computer so they are sending me another optibox that should correct the problem. I will keep you posted on this.
Hope this works nicely.
Reload this Page DELTEQ users please help!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
