Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-01-2005, 05:04 PM   #1
oldsalt
Junior Member
Default No response from ALDL
I have a 90 Corvette with ABS. Currently I have a 'Service ABS' indicator lit. Per the manual I put pin 'H' of the ALDL to ground to try and determine fault, but there is no code flashed, not even 12. Any suggestions where the problem lies? And yes, the ignition was 'ON'.
oldsalt is offline   Reply With Quote
Old 08-01-2005, 05:59 PM   #2
Blower91
CF Senior Member
Try retrieving the codes through the CCM instead. When you ground pin H the EBCM only should flash its trouble codes. Code 12 is sent by ECM (or was is perhaps CCM, don't have my books here...) so it wont show up when you grund pin H. Pull the codes through the CCM and code 12 and the others should show up.
Ground pin G (G to A) and turn the ignition on. Then the CCM will enter diagnostic mode. It displays fault codes (in speedometer) for the CCM (module1), ECM (module4) and the EBCM (module9). End of list is indicated by "---".
Best of luck!
Blower91 is offline   Reply With Quote
Old 08-01-2005, 07:55 PM   #3
oldsalt
Junior Member
Thanks for the tip. I'll give it a try.
Reload this Page No response from ALDL
Tags
aldl, response
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
IAC/IDLE Question LWesthaver C4 Tech/Performance 13 04-06-2005 09:28 AM
Any clue? FeJ9 C4 General Discussion 19 02-22-2005 05:35 PM
1988 - any problems with using scanning software ? 160 or 8192baud? Stingraynut C4 Scan & Tune 12 05-24-2004 09:18 PM
Manually controlling the lockup torque converter jimtreber C4 Tech/Performance 30 10-24-2003 04:34 PM
Lower temp thermostat install question jw38 C5 Tech 24 07-14-2002 05:49 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
