C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
07-29-2005, 11:16 PM
CF Member
88 4+3 Gear Sensor
How does the 88 4+3 tell the computer what gear it is in? Also, what bit would one watch to see if the ECU "sees" 4th gear? Or does the ECU take a ratio of RPM to speed to tell what gear it is in?
07-30-2005, 10:23 PM
CF Member
Nevermind, I found the answer by searching the forum. It is a table in the BIN file that the computer uses.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
