Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-28-2005, 05:46 PM   #1
RAGOVET
CF Senior Member
St. Jude Donor '05
Support Corvetteforum!
RAGOVET's Avatar
Send a message via AIM to RAGOVET
Default Use of Actron CP 9150
I have a 95 VERT and have used my ACTRON CP9150 to do a scan of the OBD I codes and it comes up clean. I have no trouble lights so I assume that all is well. Should I be doing something else with my scan/diag tool to check out my vehicle, or should I assume that all is well. Do all codes trigger the Check engine light???
__________________
RAGOVET
95 VERT DK Red Metallic; LT1 A4
w/3.54 rear gears; SLP Air induction CLAW; 52mm BBK TB w/port, polished heads & matched intake, comp CAM, Roller Rocker Arm 1.6, Hardened Push Rods, Xtreme duty timing chain; 28lb FI & Computer tuned; 160 deg therm; LT headers with HI FLO CATS; 2400 Stall Torque Converter; BMAD ; Carbon Fiber FRC, Coolant reservoir & valve covers; Flowmaster Force II cat back exhaust; Z06 Motorsport chrome wheels w/Sumi HTR 275/40/17; KYB Gas Shocks.
RAGOVET is offline   Reply With Quote
Old 07-28-2005, 07:17 PM   #2
Zix
CF Senior Member
Zix's Avatar
Some codes will not trigger a check engine light, but the Actron would list anything that is there...so as long as it's connecting properly and coming up clean I would say you have nothing to worry about.
Zix is online now   Reply With Quote
Reload this Page Use of Actron CP 9150
Tags
actron, cheap, cp9150
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
