Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-28-2005, 10:59 AM   #1
brookman
CF Senior Member
brookman's Avatar
Default Need Help w/Datamaster data file
I have a scan of my car from last night.
If anyone has time - can you look and see if you see anything obviously wrong with it.
Scan File
I did this in my garage the ambient temp was 100deg. f.
1988 Auto Trans.
Thanks!
brookman is offline   Reply With Quote
Old 07-28-2005, 07:37 PM   #2
Blower91
CF Senior Member
You have a fault code 42 (EST circuit), have you looked into this?
I didn't see any other obvious error. Perhaps you should take it for a drive and make logg?
Blower91 is offline   Reply With Quote
Old 07-28-2005, 10:51 PM   #3
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
Your welcome to send it to me.. I have some really neat anylizing software i've built to run off datamaster logs.
Are you still on the factory chip?
Alvin is offline   Reply With Quote
Old 07-29-2005, 10:50 AM   #4
brookman
CF Senior Member
brookman's Avatar
This is the factory chip. I think the 42 is set from when I set the timing after I pulled and replaced the heads two weeks ago. The Service Engine light is not on currently. I will find a way to power my laptop(battery is shot) and drive the car around.
Old 07-29-2005, 06:43 PM   #5
Blower91
CF Senior Member
Quote:
Then it should go away if you eg disconnect the battery for a minute or so and then re-connect it.
Sounds like a good idea
Old 08-03-2005, 11:44 AM   #6
brookman
CF Senior Member
brookman's Avatar
Default new scan file from 2 aug 2005 at 5pm
New Scan File
Thanks for looking. Should I be concerned with all the knock counts?
Old 08-03-2005, 07:05 PM   #7
Blower91
CF Senior Member
You get a second fault code when you turn ignition off (at end of data file), #46 which is VATS fail. No idea why, I thought DTCs should not be set at ignition off. My 91 does not set a #46 like this. Perhaps someone else knows if this is common behaviour for the older ECMs?
You get up to 14.9 deg knock retard during WOT, a little high I would have thought. During a good run mine is 1-2 deg and on a "bad" more like 3-4 deg. I have about 1 or 2 knock counts (at the most) during WOT. Perhaps one of the more experienced tuners out there can give you some good advice.
BLM in the range 114 to 134 is not so bad, it was a stock chip right? Scan ID 7871, that would be the ABTT bin. Do you have this code on the chip?
Hope this helps!
Old 08-03-2005, 07:51 PM   #8
brookman
CF Senior Member
brookman's Avatar
I always assumed that this was the stock chip. The only reason I would question it is that VATS is not functional on this car. I have normal keys. I have not dug around under the dash to see if the wires to the tumbler have a resistor stuck in them.
As you probably noticed - the air was hot yesterday and I don't remember what grade of gas I put in it last time I filled up.
I am concerned about the engine temp. The primary fan is wired on all the time (has been since I bought it). It has a 180deg thermostat in it.
If I get time I am going to check the base timing tonight to see if it is at 6 where I thought I left it after the top end rebuild.
Old 08-03-2005, 09:22 PM   #9
Blower91
CF Senior Member
Could not find ABTT bin but I compared your SA at WOT to the ABTR (88 man) and it appeared to be stock SA, at least as far as I could tell from your log.
Mine will hit about 190 deg F at long idling during summer time. Stock will run over 200 deg F so I think your temperature is fairly normal. Yes I noticed the IAT. Mine is lower but I removed the throttle body heater and my lower engine will help a little too.
I had some false knock problem with mine. Worn out water pump was one problem, the other was in-correct valve lash. I even had some knock counts at idle. Didn't see any of those false knocks in your log. Check initial timing and fill her up with high octane petrol sounds like a good idea.
Best of luck
Reload this Page Need Help w/Datamaster data file
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need Help w/Data kman0066 C4 Scan & Tune 10 06-13-2004 01:01 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
