Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-26-2005, 12:36 PM   #1
Blower91
CF Senior Member
Default Heated O2 sensor installed, re-tuning required?
I replaced the stock O2 sensor with a heated unit in my 91 Vette (long headers and cooler thermostat). After testing it I have some questions:
1) In my stock chip (AXCN) closed loop is entered above 50 deg C (122F), should I decrease this value a little bit now?
2) The new sensor makes a larger swing at part throttle. Old was roughly 150 to 800 mV and new is 50 to 850 mV. Expected?
3) Average BLM for every cell did not change much but max/min changed: 130/116 to 140/114, same thing with INT. Expected?
4) Voltage at WOT did not change much but output from old sensor was much smoother. Perhaps due to age and soot?
I would think the old sensor gave the ECM less accurate data (due to cooling off). The new sensor showed me that my tune was a little further off than I first thought… or should I draw some other conclusion?
ps How do you set HTML code "on" when you write a new post? Wanted to include BLM tables...
Blower91 is offline   Reply With Quote
Old 07-26-2005, 11:32 PM   #2
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
Humm, interesting..
Are you setup to burn chips? If so start getting after those VE tables.
Alvin is offline   Reply With Quote
Old 07-28-2005, 07:11 AM   #3
Blower91
CF Senior Member
Quote:
Yes I am. Did a new chip and that put the BLM back to "normal".
I had a closer look at the data.
1) Like I said, when changing from non-heated to heated sensor the max BLM of the run went from 130 to 140. You can see the BLM cells here. It seems that only cell #2 was affected by the change, just minor changes for the others. Still I hitted the same region in cell #2 with the non-heated sensor run. In both cases INT eventually settled to 128 so I guess the ECM was happy with the BLM then. So do you understad why this happens?
2) The average O2 voltage at WOT increased a little bit with the heated sensor, see here. Also the PW increased so the engine did get some more fuel. When I entered PE the BLM was 120 in the non-heated case and 128 in the other. Is it possible that the ECM compensated for the slightly rich condition in the non-heated case? It does not quite add up when comparing to the PW though.
Reload this Page Heated O2 sensor installed, re-tuning required?
Tags
c4, corvette, heated, installing, o2, sensor
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
GOT MY ILLINOIS EMISSIONS TEST INVITE - NEED SUGGESTIONS!!!!!!!! JR-CRUZN-C5 C5 Tech 18 03-16-2004 01:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
