Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-22-2005, 03:15 PM   #1
bowtie350_428
CF Senior Member
bowtie350_428's Avatar
Default Which Bit indicates the COOLING FANS are ON? DataLog From DataMasters.
This is for a 91 L98 w/ZF6.
I have a DataLogs from "TTS DataMasters" but I don't understand what I am reading in the "Status Bit Display" Frame. Can Anyone Tell me what the Following Bits are for?
Fan 1 Rqst
Fan 1 was On
Fan1 PID
Fan 2 Rqst
Fan 2 Rqst (listed twice in dialog box)
Fan 2 PID
Cool Sw
Mainly what I want to know is which flag indicates the Primary and Aux Fans are ON?
I am Trying to diagnose a problem with my Aux Fan. It won't turn on and I suspect ECM. This is link to previous post:
http://forums.corvetteforum.com/show...47&forum_id=48
bowtie350_428 is offline   Reply With Quote
Old 07-24-2005, 04:55 PM   #2
smross33
CF Member
smross33's Avatar
This may be a dumb question but did you check the fuse?
smross33 is offline   Reply With Quote
Old 07-25-2005, 03:45 PM   #3
bowtie350_428
CF Senior Member
The fans don't have a fuse. But I did change the fusable links when I changed the fan motors. Besides the problem is intermittent. Sometimes the Aux Fan turns on and off rapidly or sometimes just does switch on at all. A blown fuse would not have intermittent symptoms. I already checked the relays by swapping and regardless of which relay I use, it always happens to the Aux Fan.
I suspected the pin connecting the relay wire (Blue/White) to the ECM. But I need to know if I am interpreting the DataLog Correctly.
When I read the DataLog, bit “Fan 2 PID = 1” and “Fan 2 Rqst = 1”. The way I interpret this is the ECM is sending the signal to the Aux Fan relay to turn "ON". Am I interpreting this Correctly?
Old 07-27-2005, 11:31 AM   #4
Corvette86
CF Senior Member
St. Jude Donor '06
Corvette86's Avatar
Slave in a wire from the ECM and see if the problem goes away.
Frank
Corvette86 is offline   Reply With Quote
Reload this Page Which Bit indicates the COOLING FANS are ON? DataLog From DataMasters.
Tags
bit, coolant, datamaster, status, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
