Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-21-2005, 06:46 PM   #1
mswasty
Junior Member
Default 1994 ABS troublecode help
Hello fellow Vette Gurus,
Can someone do me a huge favor and look up an ABS code for me from their 92-96 factory service manual. It's ABS Code 65 "Adjuster Assembly Circuit Malfunction". I can't find anything about this code on the web. What the heck is the Adjuster Assembly???
Thanks a ton
Matt
mswasty is offline   Reply With Quote
Old 07-28-2005, 06:06 PM   #2
Red Dwarf
CF Senior Member
Red Dwarf's Avatar
ABS 65
The adjuster assembly circuit provides both power & ground to the adjuster assembly to help control engine torque during a TCS event.
The DTC will set when : If CKT 560 or Ckt 561 are shorted to ground, shorted to voltage, shorted to each other. or both open at the same time.
Manual advises that a thorough inspection of the wiring & connectors be performed before replacing parts.
Red Dwarf is offline   Reply With Quote
Reload this Page 1994 ABS troublecode help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
