Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-19-2005, 04:53 PM   #1
HGN CRVZ
Junior Member
HGN CRVZ's Avatar
Default Fuel Pressure reading
I have read various posts and found the proper readings for the fuel pressure, but not the indications the gauge just indicate. My 87 when hot, is starting hard and stalling. I checked the fuel pressure and found the pressure at key on to be 45#, but when I start it the pressure becomes severely erratic. It jumps between 47 and 15 almost like a burnt intake valve does on a vacuum gauge.
I originally had a code 36 from the ECM. I conducted the flow chart tests and found nothing wrong with those ckt’s and the code has since disappeared.
Any help would be much appreciated!
HGN CRVZ is offline   Reply With Quote
Old 07-20-2005, 02:47 AM   #2
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Are you sure your MAF sensor isn't going bad?
The maf will effect the injectors which would effect the fuel pressure...
Hard starting and stalling and erratic "running" is all the symptoms of a bad MAF sensor...
You can easily try unplugging it and see if things smoothen out, it relys on the MAP when the MAF is unplugged , if things smoothen out, the MAF is your problem...
hope this helps..
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 07-20-2005, 03:52 AM   #3
Morley
CF Senior Member
Morley's Avatar
Quote:
Mo
HUH? There is no MAP sensor for a backup on the OBD I systems. If you unplug the MAF sensor the ECM uses default fueling tables based on TPS and CTS readings.
Morley is offline   Reply With Quote
Old 07-21-2005, 02:10 AM   #4
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Morley,
Opps you're right ... I was thinking of my 95 which was anOBD! it did have a MAP as a backup...
Mo
Old 07-21-2005, 10:27 AM   #5
HGN CRVZ
Junior Member
HGN CRVZ's Avatar
I re-checked everything and found the vacuum hose to the regulator was dry rotted and leaking like a sive and giving the system 20 minutes to sit, the injectors leaked down. I also tried unplugging the MAF and letting the ECM run it's default table for the MAF but the motor died instantly and wouldn't crank until I plugged it back in. I'll have to dig deeper on the MAF problem, but I will try cleaning the injectors and solve that problem first. I had the injectors cleaned by GM two years ago and I just started hearing the injectors ticking again. I think I will also change the fuel filter for the sake of it.
Thanks again for the help!
Dan
Reload this Page Fuel Pressure reading
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A&A Corvette Performance:Forced Induction Q&A thread Andy@AandACorvette C5 Forced Induction/Nitrous 825 07-02-2010 01:23 PM
Fuel Pressure Gauge Question gpagaduan C4 Tech/Performance 10 10-28-2004 10:09 AM
Tough time coming up w/ fuel pressure test gauge Lone Ranger C4 Tech/Performance 25 05-02-2003 12:40 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
