Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-19-2005, 01:18 PM   #1
KingKash420
Junior Member
Default Scan tool won't communicate with ECM
my 89 c4 vette is having problems.. and the service engine light comes on and off very frequently.. so i have a friend who is good with corvettes who tried to figure out the problem.. he has an obd1 scan tool that he tried to hook up to the ecm but the problem is even after he hooks it up the scan tool says "waiting for connection" which basicially means that the scan tool is not able to communicate with the ecm.. my buddy tested the serial connection for continuity and he says it is fine.. so he told me he thinks the computer is shot.. what do you guys think is the problem.. if the computer was shot wouldnt the car not work at all?
i am hoping that maybe it is something small that can be fixed.. because i know if he could get this scan tool to work that he would be able to adjust all my parameters and get the engine running good again..
any help or input is much appreciated.. it is killing me that the vette is not running well..
KingKash420 is offline   Reply With Quote
Old 07-19-2005, 01:26 PM   #2
Morley
CF Senior Member
Morley's Avatar
read through this thread, especially the last post or 2 http://forums.corvetteforum.com/show...48&forum_id=82
Morley is offline   Reply With Quote
Old 07-19-2005, 01:27 PM   #3
KingKash420
Junior Member
Quote:
yea i checked that thread out.. so basicially you do think my ecm is shot then?
Old 07-19-2005, 01:38 PM   #4
Red Tornado
CF Senior Member
Red Tornado's Avatar
it certainly seems to me thats what he/they are saying.
Red Tornado is offline   Reply With Quote
Old 07-19-2005, 01:45 PM   #5
KingKash420
Junior Member
Quote:
how much do replacement ecm's usually go for?
and how do i know which one to buy.. my vette is a 89' c4 and its automatic
Old 07-19-2005, 01:46 PM   #6
Morley
CF Senior Member
Morley's Avatar
Quote:
Your symptoms seem almost exactly like his. Before shelling ot the $$ for an ECM...see if youcan borrow one from a friend...any Corvette or F body ECM from 86-89 will work. Just remember to put your MEMCAL in the ECM when you swap it...especially if using one from an F body.
Old 07-19-2005, 02:42 PM   #7
Bluevette85
CF Senior Member
Bluevette85's Avatar
Have you tried jumping pins A+B to see if the check engine light flashes with trouble codes? They are the upper right pins.
You might need a 10k ohm resistor between pins A+B to communicate with the scan tool.
Bluevette85 is offline   Reply With Quote
Old 07-19-2005, 02:50 PM   #8
KingKash420
Junior Member
so by jumping pins A + B instead of just saying "service engine" it will actually display me a code telling me what is wrong?
also how would i know if i need the 10k ohm resistor or not? would it help if i told you the specific name of the scan tool?
Old 07-19-2005, 05:38 PM   #9
Bluevette85
CF Senior Member
I have a '165' ecm in my car. This ecm was used from 86-89. I converted from the '870' ecm.
Put a paper clip between pins A+B and turn the ignition switch on but do not start the car. The engine light will flash once, then twice (which means code 12). It will do this 3 times then it will flash any stored codes then end with three code 12's.
Post the stored codes and we can tell you what they mean.
I don't know what your scan tool needs to work. The 165 ecm needs a 10k ohm resistor to send data to scanning software (Winaldl, Tunerpro, Datamaster). Check with the maker of the tool.
To pull the codes, you don't need a scanning tool other than a paper clip.
Old 07-20-2005, 05:15 AM   #10
hebbe
CF Member
Default codes
Do all codes disapeare after disconnecting the car-battery or are there old codes in under to pic up with more sophisticated tools ?
Thanks ! Hebbe / Glad finding this thread ! Been wondering about how to pic up the codes for a long time.
hebbe is offline   Reply With Quote
Old 07-20-2005, 08:36 AM   #11
Bluevette85
CF Senior Member
The codes clear after disconnecting the battery unless the problem remains.
Old 07-20-2005, 12:01 PM   #12
msslp04
CF Senior Member
St. Jude Donor '11
Support Corvetteforum!
msslp04's Avatar
I just went thru this same thing with my 89 with auto. It was a bad ECM. The Chevy dealer charged $150 for the ECM plus labor. I had no codes either and the exhaust smelled like it was running really rich when the SES was on.
Kevin
msslp04 is online now   Reply With Quote
Old 07-21-2005, 10:13 AM   #13
KingKash420
Junior Member
it seems like i could save some cash by buying a new ecm off ebay.. but how do i know im not just buying another dead ecm for someone else?
if i absolutley have to i can fork out the $150 for the ecm from the chevy dealer but damn my money is tight right now and i would really rather not..
any other suggestions guys?
Old 07-21-2005, 01:00 PM   #14
Bluevette85
CF Senior Member
Have you tried jumping pins A+B?
Old 07-21-2005, 02:10 PM   #15
gbody5
CF Senior Member
gbody5's Avatar
Should be around $100 from NAPA etc. I would not buy anything electrical off EBAY, or anywhere else where I could not return it and/or get at least a 1 year warranty; which is what I believe you get from NAPA for an ECM.
gbody5 is offline   Reply With Quote
Old 08-05-2005, 01:05 PM   #16
mrmuzic
Junior Member
Default Fyi
Just an FYI
Electrical items that you buy and you install are gauaranteed until yoiu walk out the door. This is the policy of almost every parts dealer. Electrical items atre guaranteed when they atre installed by a repair shop. This policy is usually posted in all the parts houses that I have ever been to.
mrmuzic
mrmuzic is offline   Reply With Quote
Old 08-05-2005, 02:48 PM   #17
gbody5
CF Senior Member
gbody5's Avatar
Quote:
Originally Posted by mrmuzic
Just an FYI
mrmuzic
Not the Carquest I patron. As long as I have the receipt they honor the warranty implied on the receipt. My ECM had a 1 yr warranty.
Reload this Page Scan tool won't communicate with ECM
Tags
1988, 82, commuicate, communicate, compter, connect, corvette, ecm, gm, hook, obd1, scan, talk, tool, wont
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
