Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2005, 04:58 AM   #1
X-SDime
Junior Member
X-SDime's Avatar
Send a message via AIM to X-SDime
Default Tuning Gains on Stock 94?
Well, as the title suggests, I'd like to know how beneficial custom tuning on a completely stock 94 coupe would be. I finally got to dyno the car the other day and it made some pretty good power (numbers in sig) but it looked to fairly rich during the pulls. Tons of black smoke. Unfortunatly the place didn't use a sniffer so I don't know the A/F ratio. Tunercat software seems pretty resonable compared to LT1 Edit so I might try my on hand at tuning. Do people usely see a decent gain in power on stock engines or am I just wastin time?
Thanks,
Eric
__________________
2002 Sunset Orange Z-28
Stock w/ Z06 Motorsports Rims
13.693 E.T. (wet track, bald stock tires)
103.23 Trap Speed
"Sold" 1994 Aqua Corvette w/ Auto
SLP Claw Intake, Muffler Elims, Taylor 8mm Spiro Pro wires, MSD Blaster Coil, MSD 6A, KYB Shocks, R-D Racing Camber Brace, Hawk Pads, Speed Bleeders, Replaced BLOWS system with Focal speakers and Pioneer Deck
Best Quarter Mile Run
13.687 E.T.
100.44 Trap speed
268.5 RWHP
299.2 RWTQ
X-SDime is offline   Reply With Quote
Old 07-18-2005, 09:26 AM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
GM did a pretty good job on tuning the LTx engines. I doubt that you will pick up much HP tuning a stock engine.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 07-18-2005, 10:26 AM   #3
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
I would suggest tunercat.
Actually theres quite a bit to be had even in stock vehicles.
Alvin is offline   Reply With Quote
Old 07-18-2005, 12:30 PM   #4
STL94LT1
CF Senior Member
STL94LT1's Avatar
Quote:
Alvin, what do you consider quite a bit? Because I've yet to see anyone post documented gains tuning a stock LT1.
Please don't misunderstand the above statement. I believe that you have made gains on stock engines. I have just never seen them posted.
-Mike
__________________
2006 Cobalt LS (DD)
Old 07-18-2005, 12:53 PM   #5
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
Typically 14 is very easy to get out of most of them.
You will hardly ever see less than 10rwhp which is a great bang per buck when you consider what a exhaust, intake, etc does.
I had a 93 a while back that was completely stock down to the original plugs.. Anyway, that car picked up 22rwhp and 28ftlbs of torque.
when you consider also that 1 mod can take care of
Fan speeds for cooler thermostats
removing CAGS
Firm shifts
Speedo calibration
Typically 14rwhp
I think its a great bang per buck for $99-$150
Old 07-18-2005, 03:51 PM   #6
X-SDime
Junior Member
X-SDime's Avatar
As far as my horsepower, how does it compare to other cars you have dyno'd and or tuned? I'm pretty sure it's in the ballpark but I'm curious.
Old 07-19-2005, 02:14 AM   #7
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
I also had not ever heard that tuning would give much on a stock car.
Good to know!
Vis Croceus is offline   Reply With Quote
Old 07-19-2005, 05:01 AM   #8
ShaneL
CF Member
Well, your dynot numbers seem pretty much the same to mine. I got 268.3rwhp and 298.6rwtq I did get an afr readout from the runs and it was hovering around 13.0 until then it started to richen? to 12.5 near the end of the run. What would be a good target afr?
I also have muffler elims as well as test pipes with k&n filter which is somewhat similar to your setup.
I have several comaprison timeslips from the day of the dyno with the best of that day's runs being a 13.549@103.06 with a 2.064 60ft (Nov of 2004).
Moving on to March I got a best of 13.425@101.07 with a 1.908 60ft. At this time I had changed to a 3000rpm stall Vigilante converter with no launch technique at all .
Again moving to April I got a best of 13.283@102.28 with a 1.865 60ft, again I am still working on the launch but the gs-d3's don't help with traction....
Latest trip to the strip: 13.247@102.42 with a 1.852 60ft. tires were slipping at launch most of the time so I wasn't able to rev the engine up as much to get as good of a launch as I wanted. May have to look into drag radials...
I have the new Tunercat for OBDII and am loving it right now but I have not been able to get any dyno time to play around with the a/f ratio at wot but I will soon (hopefully).
-Shane
ShaneL is offline   Reply With Quote
Reload this Page Tuning Gains on Stock 94?
Tags
gain, gains, lt1, stock, tune, tuning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Newbie Modification Questions - 1995 Corvette Convertible LT1 LawVette C4 Tech/Performance 22 08-10-2011 01:48 PM
Any numbers from a before and after LS2 edit? jimman C6 Tech/Performance 73 06-03-2005 08:09 PM
CARMAX GUY BLEW MY MAGNACHARGED MOTOR TODAY!!!! vettewreck C5 Forced Induction/Nitrous 39 05-17-2004 06:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
