What #'s are you using for the dyno section of tts data master?
mainly weight, frontal area, drag coefficient and drivetrain loss.
My car is a 92 with a vortech.
The car is slammed up front and dropped in the back a bit too. No wings or spoilers.
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
thanks wayne. BTW, you're going to be getting some mail either tommorrow afternoon or Wednesday.
So by plugging in 20%, that's comparable to what you see on a dyno for rwhp? I thought it was flywheel but hey, that's even better if so.
How about output factor?
__________________
Those are numbers that use, i had the car weighed with me in it after installing the S/C and it had a 1/2 tank of fuel... the drag coefficent was gathered from a couple simulation programs i use...
20% is probably pretty darn close... sorry I can't help you on the putput question..
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
what output filter are you using once you input all your info?
The curves kind of make sense on output filter 2. The blue line, torque is higher at the lower rpms, and the red, approaches the torque curve toward the higher rpm. The thing that I don't understand is why the torque curve on my graph keeps climbing from 4000 rpm to 4900 rpm where I cut it off. Measurements were taken in third gear on my auto.
