Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2005, 08:22 PM   #1
qwiketz
CF Senior Member
qwiketz's Avatar
Default code 15- engine coolant temp sensor
Well I thought I would have gotten rid of the datamaster dtc err....
I previously broke the coolant sensor when trying to do a pulley change. I replaced it and now it registers but still gives me a dtc error, citing #15. I replaced it with a borg warner sensor from pep boys. The coolant temps look to be correct(on the datamaster screen) yet it's still giving me the error code. What gives?
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 07-17-2005, 08:32 PM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
Try resetting the code, and see if it comes back.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 07-17-2005, 08:36 PM   #3
SunCr
CF Senior Member
Did you clear it?
15 usually means the signal or ground wire is open. Check the wiring by jumpering the harness terminals to see if it generates a 14. If not, check for 5 volts on the signal wire and check ground for an open. If you don't get the 5 volts, check for it at the ECM to confirm or rule out the wire. If it isn't at the ECM, you'll need a new ECM. Ground for most years is shared with the TPS and MAT, so if you don't have those codes, you only need to follow it back through the harness to the splice.
SunCr is offline   Reply With Quote
Old 07-17-2005, 11:56 PM   #4
qwiketz
CF Senior Member
qwiketz's Avatar
Clear it? I don't even know what that means. This is my first time running datamaster and my first problem with the car.
I'll check it for 5 volts next Saturday. 15 is the only code I'm getting right now. Everything else is green on the datamaster program.
Old 07-18-2005, 01:27 AM   #5
qwiketz
CF Senior Member
qwiketz's Avatar
on a side note... the check engine light went off when I changed the engine coolant temp sensor.
__________________
Old 07-18-2005, 01:44 AM   #6
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
Sounds like you need to clear the codes.
Datamaster will do this for you, although a bit crudely if you turn the key on, engine off and click Clean malf. in the Start stop monitor box
or you can pull the ECU fuse
Alvin is offline   Reply With Quote
Old 07-18-2005, 01:46 AM   #7
qwiketz
CF Senior Member
qwiketz's Avatar
awesome! I'll give that a try. I haven't seen that in the manual yet so I'll give it another once over.
thanks for all the help today!
Old 07-18-2005, 10:04 PM   #8
qwiketz
CF Senior Member
qwiketz's Avatar
update... the funny thing is when the sensor was not connected at all, the car would cold start fine and then run rich once it was hot because the sensor was reading about 30 some degrees. Now that it's fixed, the car starts like crap when cold (how cold could it be here in CA where it's 80* in the morning) and runs fine afterward once hot. When started cold now it idles really low and feels like it's not running on all 8 cylinders. This is so wierd....
Reload this Page code 15- engine coolant temp sensor
Tags
15, 84, 92, c5, clear, code, codes, coolant, corvette, datamaster, engine, location, sensor, temp, temperature, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
code 54 - Low Fuel Pump Voltage - What to check next? HoustonBob C4 Tech/Performance 9 05-30-2004 04:01 PM
First real problem in years: Code 15 but much more! PeteL C4 Tech/Performance 17 01-16-2002 07:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
