Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-17-2005, 10:30 AM   #1
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Default 7749 communications trouble (need help)
Quick overview. 91 covette with a 7749 wired in (correctly?) using the 91 memcal and the $58 mask. Diacom/pocket programmer/TunerCat
I can't communicate with the ecm with the $58 mask. If I use my stock memcal and chip, I can. I am getting a SYS that flashes 3 times and then goes back to the fuel information. 20 seconds later, SYS flashes 3 times again. Right now I am using a 27SF512 chip. I believe the $58 mask is 16k, so I offset my chip and start it at 0C000. To help troubleshoot, I burned a stock 91 program onto the same chip, used the adapter, and I could communicate with that as well. Any suggestions would be welcomed at this point.
__________________
91 (383 LT1 turbo, under construction)
92 (Heads, Cam, Exhaust)
ANTI VENOM is offline   Reply With Quote
Old 07-17-2005, 12:40 PM   #2
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
I have no first hand expereience with the 749 but it sounds like you that your probally just not using the right scanning definition.
Alvin is offline   Reply With Quote
Old 07-17-2005, 01:48 PM   #3
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Do you also get a SYS flash with the stock bin in the 7749 ecm? I think in any case you will get a SYS flash because the 7749 ecm can't communicate with the CCM. You should be able to talk to the ecm with your diacom software. I am not sure if your offset is correct using a 512 chip. You could try stacking the bin onto the chip using Moates bin stacker. Seeing how you are using a 512k chip it would be 4x16k if you stack it on the chip you have now. I usually use a 27SF256 chip and place 2 16k files on it. The problem maybe with the use of the 512k chip in the ECM that was designed for either a 27C128 or a 27C256 chip. I don't have the specs for the SST 512 chips here to see if electrically they are compatible. I have used them in truck ecms and also in later F and Y car ecms that originally uses a 256k chip.
tjwong is offline   Reply With Quote
Old 07-17-2005, 02:13 PM   #4
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Tom, I don't get the sys light when I use the stock .bin. I also have some Atmel 29c256's that I will try instead.
Alvin, right now I am scanning with Diacom, and I put in a 91 Syclone Vin number and then select the turbo model. I have had trouble connecting to some vehicles with Diacom, but I thought the SYS light on the dash was a give away that something else was wrong.
__________________
Old 07-17-2005, 10:17 PM   #5
Blower91
CF Senior Member
The SYS will flash 3 times every 15 sec while a currect-code fault is present. Have you tried grounding pin G through pin A in the ALDL connector to retrieve the CCM fault codes?
Code 41 will set if the ECM does not respond to the CCM poll. My guess is that the $58 code does not have support for the CCM, I could be wrong though...
Blower91 is offline   Reply With Quote
Reload this Page 7749 communications trouble (need help)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
