Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2005, 11:14 PM   #1
Strike3
CF Senior Member
Strike3's Avatar
Default First time tuning...Help !!
I have a 1987 coupe with L98 engine. I purchased a Moates Auto Prom with all the bells and whistels, Tuner Pro RT software and a bin file called 88CORV32. (Closest we could get to my car)
My firse problem is getting the bin into the Tuner Pro software in order to edit it.
After downloading all the software, Tuner Pro RT and the bin both appeared on my desktop each with their own Icon. Actually the bin has 2 Icons. 1 is a file which appears to track changes or edits to the bin, and date stamps them.
Anyway, When I bring up Tuner Pro and go to "File" I am unable to get the 88CORV32 to upload into tuner-pro so that I can edit it. I played with it all afternoon and was never able to get anything to happen except for the file name "88CORV32" to apear in a heading.
I was noticing the bin file is only 407 bites. Is this typical, or a clue to the real problem??
What the hell am I doing wrong??
Strike3 is offline   Reply With Quote
Old 07-15-2005, 11:49 PM   #2
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
If you send me a email with all your vehicle info IE gear, tranny, year I can send you a stock bin that I know works.
Other than that I can't relaly help you with tunerpro, i've never been a fan of it. I like Tunercat RT bette.r
Alvin is offline   Reply With Quote
Old 07-16-2005, 12:00 AM   #3
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
It appears that your bin file is corrupted. The file size should be 16kb. Alvin can supply you with a stock calibration that will work.
tjwong is online now   Reply With Quote
Old 07-16-2005, 02:25 AM   #4
Morley
CF Senior Member
Morley's Avatar
You didn't mention an ECU file...you need the $32b ECU file also, for editing.
Morley is offline   Reply With Quote
Old 07-16-2005, 02:31 AM   #5
Strike3
CF Senior Member
Strike3's Avatar
Yes, that is the correct mask.
I also have Tuner Cat, but I'm having a problem getting it started. My pasword doesn't work, and I'm waiting for a new one. I suspect it will be Monday before I recieve that.
Old 07-16-2005, 01:10 PM   #6
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
John is pretty good about only working M-F till 5pm. I would imagine you would have it promptly at monday morning.
Did you try the binary I sent you? Did it make a difference?
Old 07-17-2005, 11:36 AM   #7
Strike3
CF Senior Member
Strike3's Avatar
Hay Alvin !!
I haven't received your bin yet. I'm wondering where it went. Let me check my profile to see if I have left an old e-mail address there.
Thanks!
Later
Old 07-17-2005, 12:39 PM   #8
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
I replied back the night that you sent it.
I'll be out of town M-thrusday so if you need it you ought to try to send me anthor one today from a known good email address. My email is chips@pcmforless.com
Old 07-18-2005, 12:19 AM   #9
BlackC6LS3
CF Senior Member
BlackC6LS3's Avatar
Send a message via AIM to BlackC6LS3 Send a message via Yahoo to BlackC6LS3
not to highjack the post but where can i find a bin and ecu file for a 93 corvette?
thanks in advance
Dave
BlackC6LS3 is offline   Reply With Quote
Old 07-18-2005, 01:27 AM   #10
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
I've got a crapload. 1000+ If anyone needs any they can email me at chips@pcmforless.com and i'll look it up for them.
Reload this Page First time tuning...Help !!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
First time with LS1 Edit and Scanner - LTFT results BLOWNZO6 C5 Scan & Tune 11 10-02-2004 01:28 AM
First time@dyno, now I'm depressed... Alcee1 C4 General Discussion 24 03-20-2004 11:15 PM
Where did my MPH go? First time at the track. Corvette0096 C4 Tech/Performance 26 05-27-2003 01:11 AM
CARTEK-- 422 C5 AUTOMATIC GOES 10.93 FIRST TIME OUT!!!!! black thunder C5 Tech 35 07-27-2002 02:21 AM
First Time at the track, 3 Runs. !/4 mile times VERY disappointing BlueC4 LT1 C4 Tech/Performance 28 09-25-2001 02:32 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
