Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2005, 06:23 PM   #1
FRBvetteguy
Junior Member
FRBvetteguy's Avatar
Send a message via MSN to FRBvetteguy Send a message via Yahoo to FRBvetteguy
Default PO400 EGR Problem
So I have a 1996 Vert and I have a quick one for anybody that has run into this before.
The system has all new parts in it: ie. egr valve, solinoid, air injection valves, (which made a differance in the time it takes for the light to come back on) and everything else checked out. A long drive with the scanner running a graph chart shows no problems. I believe the problem is in the PCM, but I cant prove that yet. Any help would be greatfull.
Thank you.
FRBvetteguy is offline   Reply With Quote
Old 07-16-2005, 03:10 AM   #2
Dan Parker '96
CF Senior Member
The last time I had a P0400 code was when I was stock and legit.
The cause was a failed EGR valve diaphram. I replaced the EGR valve and all was good.
Since you have a new EGR valve I would check the vacuum connections to the valve as well as the other vacuum connections (can't remember them off the top of my head but there are other vacuum lines associated ... along with a solenoid).
It's possible that one of these lines is ruptured or the solenoid is bad.
Testing the lines is easy. Disconnect and put your finger over one end... suck on the other. No jokes, please.
I'm not sure how to test the solenoid.
I bitch about this but .... buy the real shop manuals.. www.helminc.com
They are invaluable.
Dan Parker '96 is offline   Reply With Quote
Reload this Page PO400 EGR Problem
Tags
1996, 96, c4, code, corvette, egr, engine, p0400, po400, problems, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SES light on, Autozone says its EGR valve bradlasvegas C4 Tech/Performance 12 08-07-2005 12:16 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
