Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2005, 12:57 AM   #1
SHINOBI-X
CF Senior Member
SHINOBI-X's Avatar
Send a message via Yahoo to SHINOBI-X
Default MAP(Kpa) question
just curious about MAP(KPA) at idle for mostly stock C4's or even you modded motor guys? i saw on a snap on scanner today at my shop that my 84' vette was around 34. does this sound too lean or just right? can someone explain to the noob here about MAP(kpa)?
a big thanks to all
SHINOBI-X is offline   Reply With Quote
Old 07-15-2005, 09:57 AM   #2
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
That sounds about right. My stock 94's MAP Kpa at idle was 32-33. Now that it's modded, that has been raised to ~58 Kpa.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 07-15-2005, 11:41 AM   #3
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
MAP Pressure can be a little misleading to some. All it is is manifold pressure. At atmospheric pressure meaning zero vacuum your MAP sensor would indicate approximately 101 Kpa. At its highest vacuum the MAP sensor could read 1 to 5 kPA and that is if the engine could produce enough vacuum to pull it down that far. A totally stock engine would typically produce higher vacuum levels than that of a cammed up modified engine. Stock engines would idle around 30 to 40 kPA, while modified engines with cams would range from 50 on up. Heavily modified engines with large cams would idle at around 60 on up. That 572 620hp crate engine idled at 1000 RPM with about 60 kPA of vacuum.
tjwong is offline   Reply With Quote
Old 07-16-2005, 12:37 AM   #4
SHINOBI-X
CF Senior Member
SHINOBI-X's Avatar
BIG THANKS!
Old 07-16-2005, 12:44 AM   #5
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Hi TJ!
Mo
Mo_Bandy is offline   Reply With Quote
Reload this Page MAP(Kpa) question
Tags
kpa, map, vacuum
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Injector Flow Rate Question QuickSilver2002 C5 Scan & Tune 9 07-29-2002 11:06 AM
Craig Moates software (like Diacom) just updated, available now! Craig Moates C4 Tech/Performance 16 10-07-2001 05:53 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
