Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Scan & Tune
C4 Corvette Performance Chips, ECM/PCM Modifications, Dyno Tuning, Fuel Management, Tuning Software
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-14-2005, 02:47 AM   #1
evilryu530
CF Member
evilryu530's Avatar
Default How do you check codes?
How do you check codes? on imports, you take a paperclip and connect the 2 pins together on the ecu to get the flashing code on the check engine light. how do you do it on the corvette? i have a 1984. thanks.
evilryu530 is offline   Reply With Quote
Old 07-14-2005, 11:09 PM   #2
illinest
CF Senior Member
illinest's Avatar
i also would like to know. i have an 86
illinest is offline   Reply With Quote
Old 07-15-2005, 12:29 AM   #3
illinest
CF Senior Member
illinest's Avatar
nevermind evilryu, i figured it out and here is how it works.
under the steering wheel by your right knee is the diagnostic connector, short pin A to pin B (the pins on the far right on top row)
turn key on but dont start engine. You will see check engine light start to flash
flash - flash flash (code 12)
flash - flash flash
flash - flash flash
then you will see your fault codes next
flash flash - flash flash flash flash (code 24)
when your fault codes are done you will see code 12 three more times.
post up here when you have all your fault codes and someone will help you, or you can buy a haynes or chiltons manual and they will be listed therein.
Old 07-24-2005, 01:28 PM   #4
valkryder
CF Senior Member
valkryder's Avatar
I don't get how you read code 12 out of 9 flashes, or code 24 out of 18 flashes???
What am I not seeing?
valkryder is offline   Reply With Quote
Old 07-24-2005, 02:31 PM   #5
vette-rookie
CF Senior Member
It flashes once then twice = 12. It will do that 3 times then tell you the codes. It will tell the codes 3 times as well, then flash 12 three times to tell you its the end of the codes.
So if it flashes 3 times then 2 times that equals code 32.
vette-rookie is offline   Reply With Quote
Old 07-28-2005, 12:06 PM   #6
valkryder
CF Senior Member
valkryder's Avatar
Got it. I checked the codes last night and got a 24, vehicle speed sensor. I'll try and get under to check the electrical connection. I can't see a problem in driving it with this code though. I'm not sure what this sensor does. Anyone know?
Old 07-30-2005, 12:14 PM   #7
illinest
CF Senior Member
illinest's Avatar
same code as i got....
your car is before abs so i would guess it can only be the speed sensor on the transmission, ive heard that you can disconnect it, clean it, check the wires for connection and put it back on, then the problem should be cleared.
unless the sensor is bad.
you'll need to get your car up in the air to check it out, and the cost of new sensor if it IS bad will be in the 60 to 70 range most likely.
Reload this Page How do you check codes?
Tags
84, check, checking, codes, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do you get codes for troubleshooting? Balrog C4 Tech/Performance 14 12-20-2001 07:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
