How do you remove harmonic balancer
Can anyone please tell me how to remove a harmonic balancer on my 96,LT-1,auto vette.I have an front oil leak,i think it may be the oil pan,timing chain cover,etc.Looks like the front bracket is to close to pull the balancer off w/ a puller.Also,is their a way to check out the opti-spark while I have everything off.My vette has 45,000 miles on it and it runs fine.Any info you can give me would be of great HELP.Thanks
Mine just pulled right off, I've seen a guide say to take a block of wood, put it against the back and hit with a hammer, and to go back and forth between sides til it comes off.
Yes, I am talking about the hub.And do I have to jack up the engine for the hub to clear?Thanks
What kind of a hub puller do you use,if a reg.one does not work.Thanks,
Location: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
1 Post
There is a good chance you will need to loosen the oil pan some to get the timing chain cover back on right (putting it back together)
Originally Posted by Vettetobet
tip: crack the pulley bolts while the accy belt
is still on. That keeps it from turning
This is the most useful and critical tip in my option.. if you miss this step getting those bolts loose is a PITA!
