1994 6spd, what rear gear ratio?
Old 01-12-2005, 12:20 PM
Firevette
Firevette's Avatar
Cruise-In X Veteran
Default 1994 6spd, what rear gear ratio?
What rear gears were offered in 94 with the 6 speed? Anyone know of a database anywhere with this information for different years etc?
Old 01-12-2005, 12:49 PM
VR'92
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Most likley it is a 3.45
Old 01-12-2005, 01:03 PM
Firevette
Firevette's Avatar
Cruise-In X Veteran
thanks! did they all come in this ratio? or was it an option?
Old 01-12-2005, 02:04 PM
95PoloVert
95PoloVert's Avatar
All M6's came with 3.45.
The A4's came with 2.59's, with the 3.07 optional.
You can verify the ratio by checking the bottom of the diff case. It should be stamped, along with the date installed, etc.
Old 01-12-2005, 02:06 PM
Perfusion
Perfusion's Avatar
Bingo...
Old 01-12-2005, 02:07 PM
Firevette
Firevette's Avatar
Cruise-In X Veteran
Thanks!
Old 01-12-2005, 02:24 PM
kwik_ta
kwik_ta's Avatar
Location: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
didn't the 91 or 92 come with 3.54's??? I know one year had an off ration than the others.
Old 01-12-2005, 02:55 PM
Z-07 freak
Z-07 freak's Avatar
Location: Why are there squished peanut butter cups in my underware?
That's correct for the `94 model year.
Old 01-12-2005, 02:59 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
I think the 84 4+3's and the 1990 ZR1's came with 3.54's, all other manuals were 3.45. (correct me if I'm wrong)
Old 01-12-2005, 03:25 PM
bogus
bogus's Avatar
In the C4 Tech FAQ, there is a link to the C4 RPO FAQ.
Check that... This has been beaten to death... trust me on this.
Old 01-12-2005, 08:36 PM
ZF Six
Support Corvetteforum!
ZF Six's Avatar
ZR1s had 3.54s, I don't know about the '84 4+3. I know for sure that 1989-90 6 speeds had 3.33s, then in '91 they bumped it to 3.45 and it was like that until the C5s came out, on 6 speeds.
Old 01-12-2005, 08:54 PM
bogus
bogus's Avatar
Check this link:
http://forums.corvetteforum.com/showthread.php?t=956104
And this link:
http://forums.corvetteforum.com/showthread.php?t=956100
The 1990 ZR1 was the only year with the 3.54 - they went to 3.45 in 1991. It could explain why the 1990 has been considered the quickest of the bunch.
Old 01-12-2005, 11:24 PM
Z-07 freak
Z-07 freak's Avatar
Where are you guys coming up with ZR1s having 3.54s?
The `89 prototypes? Yes.
But the others?
Old 01-13-2005, 01:51 AM
jhong321
jhong321's Avatar
But the others?
I have heard that the cars that where made for the outside market (not uS) had the 3.54 and all the us cars had the 3.45. Correct me if i am wrong
Old 01-13-2005, 02:06 AM
bogus
bogus's Avatar
Old 01-13-2005, 03:23 AM
BlackbirdZ07
BlackbirdZ07's Avatar
My '92 6 speed LT1 came with 3.54 gears FROM THE FACTORY. The RPO code is GH0. I don't know what years that GH0 was an option, but it was available in 1992. By the way, mine is a US car, so this was not some export-only option.
Unfortunately I don't have access to my C4 Corvette Specs book, but it has all this kind of information.
Old 01-13-2005, 11:23 AM
Z-07 freak
Z-07 freak's Avatar
Originally Posted by bogus
That's an `89 prototype. All 84 of them have the 3.54 axle ratio.
To 1994 6spd, what rear gear ratio?
Old 01-13-2005, 02:46 PM
bogus
bogus's Avatar
answers that, eh?
Old 01-13-2005, 04:02 PM
Z-07 freak
Z-07 freak's Avatar
Not really,
Just curious where you got that from.
Old 01-13-2005, 04:25 PM
VenkmanP
VenkmanP's Avatar
It only shows up in the online RPO lists for 89-90.
Quick Reply: 1994 6spd, what rear gear ratio?
