Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C4 Corvette Discussion not covered in Tech Sponsored by
Marc Heitz Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-11-2004, 12:25 AM   #1
Nathan Plemons
CF Senior Member
Default Turn signal lever, how hard to replace? (1992)
I think there is a small short in my wiper controls. If I set the lever to it's longest time delay setting, sometimes it will work, other times it will just start running as if I've got the wipers on low. I can click it up to the second setting and it works just fine. Of course local weather patterns would require the first setting more often than not.
I actually saw the exact lever in the "HELP" parts section of the local auto parts store. It was cheap enough, it just happened to be white instead of orange. Naturally the orange would be better but if it's too expensive I might consider the white one.
Before I do anything though I need to know how hard it is to replace such a thing. I don't have the slightest clue how this comes apart. Do I have to take the whole column apart?
Nathan Plemons is offline   Reply With Quote
Old 12-11-2004, 12:51 AM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
no, that isn't the part that don't work.
sadly, it's the expensive "multifunction switch" inside the column.
I did a tech tip on this last year.
The twisting function only turns the switch inside the column.
Whilst in there, it's best to replace the turn signal and do the repair to the tilt.
I have the reciept in a folder in the garage. It has all the part numbers on it. I will get it tomorrow evening...
Here is the link - http://corvetteforum.com/techtips/vi...=264&TopicID=2
the downside is that the damned software screws up the formatting. sorry.
bogus is offline   Reply With Quote
Old 12-11-2004, 07:54 AM   #3
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Support Corvetteforum!
Mr Mojo's Avatar
Send a message via ICQ to Mr Mojo Send a message via AIM to Mr Mojo Send a message via Yahoo to Mr Mojo
You ain't kidding, HOLY CRAP!
I'm going to see if Bigtoe can fix that.
Mr Mojo is offline   Reply With Quote
Old 12-11-2004, 12:51 PM   #4
bogus
CF Senior Member
yea, royally pissed me off when it was posted. can't read it... you know me better than that - I use the enter key!!!!
Old 12-11-2004, 01:09 PM   #5
stingraymarc
CF Senior Member
stingraymarc's Avatar
Send a message via AIM to stingraymarc Send a message via Yahoo to stingraymarc
Default turn signal..
hey andy,
I think you and other fellow CF'ers posted in response to this question before, but I must ask again, is this the only way to fix a broken turn signal indicator, which is the problem I have with my 93...it won't stay in the "UP" or right turn position..down/left turn works fine...thanks
stingraymarc is offline   Reply With Quote
Old 12-11-2004, 01:27 PM   #6
newbecorvetteguy
CF Senior Member
newbecorvetteguy's Avatar
I like this link myself, it has pictures.
stingraymarc, yours sounds like a turn signal switch issue to me. Two things to check are the little curly Q springs in the turn signal switch. They break sometimes. They can be replaced without replacing the entire switch if you can find them. Usually when they fail, the problem is the turn signal won't cancel though. The other thing is the round white plasitic piece that's just under the lock plate. The part that slids over the shaft is a cam shaped piece of plastic that hits those little springs when you turn the wheel, that's what cancels the turn signal. I think if you pull the wheel and look you'll be able to see if there is a problem with one of those things, or if the switch is actually broken
http://home.t-online.de/home/O_Scholz/steering.html
newbecorvetteguy is offline   Reply With Quote
Old 12-11-2004, 01:39 PM   #7
Justardnck
CF Senior Member
Justardnck's Avatar
Quote:
Originally Posted by stingraymarc
hey andy,
You will need to pull the steering wheel and the lock plate to get at that....sorry. Its not that bad though.
Justardnck is offline   Reply With Quote
Old 12-11-2004, 01:42 PM   #8
SPEED750
CF Senior Member
SPEED750's Avatar
I just had this same wiper problem with my 92 last week. My mechanic buddy said alot of times it's the circuit board inside the wiper motor. So 3 screws later I have the board out. We look it over for bad solder joints, it all looked fine. The 2 plugs that go into it were all gumed up from being 12 years old. So I cleaned all the contacts, plugs ect. and reassembled. Make sure the blue cam on the board is put back in the correct position.
I might just be the lucky one, but it works perfect now. I would try this before you spend any money. It took a total of 15 minutes.
SPEED750 is offline   Reply With Quote
Old 12-12-2004, 12:51 AM   #9
bogus
CF Senior Member
the tools are nice to have... they are only $30.00 total at pepboys.
It's not bad... one thing, it's easier to remove the column from the car than to try doing all this inside the car...
take the airbag and wheel off first, then the lock plate, then remove it and set it in a table vice.
it is not bad, either. Expect 2 hours start to finish...
Oh, 1992 is a transitional year for columns. When you order the tilt kit, they will ask if you have a new or old style column. The best bet, take a close look up under the dash (you will have to take the knee pad off) and check the serial number. Its stampped on top of the column.
It's easiest if you drop the column off the dash and let it sag down some... write down the serial number, then the parts guy will know if the column is old or new.
Old 12-13-2004, 01:05 AM   #10
stingraymarc
CF Senior Member
I took a look at parts in the ecklers online catologue and did a search for turn signal parts, and came up with a turn signal cam for $7.99, a turn signal switch which was 39 dollars, and the actual turn signal switch for 79 dollars. In what likelihood is it that it is just the cam itself that broke and not the switch?
Old 12-13-2004, 02:47 AM   #11
bogus
CF Senior Member
not for this problem. he is describing a problem with the wipers.
Old 12-13-2004, 10:27 PM   #12
newbecorvetteguy
CF Senior Member
I saw the little springs at either NAPA, Carqwest, or Autozone not too long ago. Probably in the HELP section. Hard to give odds on the likely problem. You about have to pull the steering wheel and lock plate and take a look. Not a big deal. You should be able to tell what's going on then.
Reload this Page Turn signal lever, how hard to replace? (1992)
Tags
1992, blinker, cortvette, corvette, lever, mechanism, remove, removing, repair, replace, signal, steering, turn, turnsignal, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
