C4 Rpo Faq
C4 Rpo Faq
It happens all the time... people want to know how to break down the Regular Production Order (RPO) codes on their new C4!
Let's create our own list, and not send members to other forums!
To find your RPO code, check under the center console, or the left rear storage bin.
Confirm that the VIN number matches your car! It's quite common for a new center console to be installed without consideration for the RPO sticker!
If you want a build sheet, contact the Nation Corvette Museum at http://www.corvettemuseum.com/.
Some of these RPO's, I am sure came from The Corvette Black Book (various years) by Michael Antonick.
Some of these RPOs are independant of themselves. For example, one RPO indicates that the manual transmission was selected, where another indicates WHICH manual, even though only one was available... which must be some kind of leftover from when there were 3 different manual transmissions (back in the 60s, there was the 3 speed and two different 4 speeds).
First off, though, what is an RPO? It is the Regular Production Order code. These codes were assigned by GM to keep track of options and activities during the manufacturing of a car. These numbers are not reflective of anything other than what code was available at the time it was assigned. However, some codes have taken on meanings unto themselves, such as the Z28 Camaro, or the ZR1 Corvette. The "Z28" and "ZR1" are both the RPO codes assigned to that option package.
Same thing goes for the old W30 Cutlasses and WS6 Firebirds of the day. At times, GM will establish an RPO that stays within a specific option group. For example, the LT1 option has been reused, as has LS6. They both harken back to a bygone era and sound cool. In short, they are instantly recognised as being performance options.
The list:
1YY07 - Base Coupe
1YY67 - Base Convertible
1AZ - Modification stock order or order sold
1SB - Marketed option package 2
24S - "Removable Roof Panel, blue tint"
64S - "Removable Roof Panel, bronze tint"
AC1 - Power Passenger Seat
AC3 - Power Driver Seat
AJ3 - S.I.R. system (driver side only) 90-93
AK5 - Front seat S.I.R. system (driver & pass.) 94-96
AQ9 - Leather Sport Seats
AR9 - Base Leather Seats
AU3 - Power Door Lock System
B2K - Callaway Twin Turbo Engine (on Bowling Green Twin Turbos)
B4P - Fan, Aux Cooling, Electric
BGR - Bowling Green assembly plant
C05 - convertible folding top
C2L - Dual Removable Roof Panels
C49 - Electronic Rear Window Defogger
C60 - Manual Air Conditioning Controls
C68 - Electronic Climate Control
CC2 - Auxiliary Hardtop (convertible only)
CC3 - Removable Plastic Roof Panel
CF7 - Removable Roof Panel (Solid Body Color)
D3X - Speedometer Driven Gear (25513049)
D4L - Speedometer Driven Gear (25513050)
D7B - Speedometer Driven Gear (25513043)
D7C - Speedometer Driven Gear (25513045)
D8E - Vehicle Speed Sensor (10456021)
D8F - Vehicle Speed Sensor (10456022)
D8H - Vehicle Speed Sensor (10456039)
DC7 - Electronic LH & RH Outside Mirrors
DC8 - Electronic LH & RH Outside Mirrors
DL5 - roadside service information decal
DL8 - LH/RH Heated Sport Mirrors
E5C - Delete speedometer adaptor
E9Z - Delete speedometer key
EXP - Export
F45 - Adjustable Suspension
FE1 - Base suspension
FE3 - sport suspension (96 Z51)
FE7 - Heavy Duty Suspension
FE9 - federal emissions
FX3 - Adjustable Suspension
G44 - 3.07 Rear Axle Ratio
G87 - ring gear 8.50 inch
G92 - Performance Axle Ratio
GHO - 3.54 axle ratio
GM1 - 2.59 Rear Axle Ratio
GM3 - 3.45 Rear Axle Ratio (8.5 in. Ring Gear)
GT7 - 3.33 rear axle ratio
GU2 - 2.73 Rear Axle Ratio
IP3 - Interior trim design P3
J55 - Heavy Duty Brakes
JL9 - Antilock Front and Rear Disc Brakes
K05 - Engine Block Heater (Canada Export only)
KC4 - oil cooler
KG9 - 140 amp generator
KW2 - 124-Amp Generator
L83 - 1984, standard engine, Crossfire, 350ci, 205 hp.
L98 - 1985-1991, standard engine, 350ci, 230~250hp.
LT1 - 1992-1996, standard engine, 350ci, 300 hp.
LT4 - 1996, optional engine, available only with manual transmission, 330hp
LT5 - 1990-1995, optional engine, part of ZR1 package, 375hp, in 1993, upped to 405hp.
MD8 - 4-Spd. 4L60 Automatic Transmission
ML9 - manual 6-speed, ZF-transmission
MN6 - 6-speed manual transmission
MX0 - automatic transmission
NA5 - Federal Emission systems
NK4 - Sport Leather Steering Wheel
NN5 - California Emission Requirements
QA1 - Wheel, 17 x 9.5, Aluminum
QA2 - Wheels, 17 x 9.5 (Front) 17 x 11 (Rear), Aluminum
QB6 - aluminum wheels 17 x 8.5" front, 17 x 9.5" rear
R9Z - Control sales item 100
T61 - Daytime Running Lights
U19 - Miles & Kilometers Dash Cluster
U1F - Delco Bose Stereo System w/ CD
U52 - Electronic Instrument Cluster
U75 - Power Antenna
UJ6 - Low Tire Pressure Warning System
UM6 - "Bose Stereo w/ CD & Cassette, Seek/Scan, Clock, ETR Radio"
UU8 - Delco Bose Stereo System
UXO - Dual Floor Sill & Extended Range Speaker System
VM3 - information label, bumper impact standards
V56 - Luggage Rack (convertible only)
V73 - Vehicle statement, US or Canada
XAA - front tire P255/45 ZR17
XAU - Front Tire, P275/40ZR17
YAA - rear tire P285/40 ZR17
YAU - Rear Tire, P275/40ZR17
YBE - Rear Tire, P315/35ZR17
Z07 - Handling suspension
Z51 - Handling suspension
Z52 - Handling suspension
Z5G - Identification, Callaway Orders (not listed on SPI label all years)
ZR1 - Special Performance Pkg.
Colour codes:
Exterior
10U - Arctic White exterior
Interior
70I - Torch Red interior
703 - Torch Red leather
Rear Differentials
This topic gets picked on quite frequently. Time to clarify it. There are two differentials, the D44 and the D36 (not RPO codes), both made by Dana. The D36 is standard on the automatic and the D44 is standard on the manual, expection being 1984, when the D36 was the only one available.
These are the codes related to the rear gearing, with the differential that they use:
G44 - 3.07 Rear Axle Ratio - D36, optional; D44, standard, pre-1992.
G92 - Performance Axle Ratio - Shows performance axle selected.
GHO - 3.54 axle ratio - D44 only.
GM1 - 2.59 Rear Axle Ratio - D36 only.
GM3 - 3.45 Rear Axle Ratio - D44 only.
GU2 - 2.73 Rear Axle Ratio - D36 only.
What this means is this, G92 is not dependant on a specific ratio or differential housing. It's just an indicator, a rather redundant one when you think about it.
There is a D44 offered with a 3.33 or 3.31, don't have that RPO yet.
Thanks for providing RPO's!!!
- *89x2*
- 90EXPVette
- jd v3tt3
- ODA CDR
- Strike3
- vms4evr
- Z07 freak
Ok, let's start filling in these blanks! As you all add them, I will post them in this document, then yours can be deleted, to keep the thread smaller.
Same goes for errors and such! This thread does not need to get to 1000 posts.
The list:
1YY07 - Base Coupe
EXP - Export
KC4 - oil cooler
U75 - Power Antenna
Colour codes:
Exterior
Interior
Rear Differentials
- *89x2*
- 90EXPVette
- jd v3tt3
- ODA CDR
- Strike3
- vms4evr
- Z07 freak
Location: ...tearing up the highways, one state at a time™®©
Received 2,094 Likes
B2K - Callaway Twin Turbo Engine option (on Bowling Green Twin Turbos)
I have a 90 6 spd coupe, my Label has GT7 & G87; none of the codes listed above. Anyone know what these are? i was under the impression the manual trans cars had 3.07's...
DKMCW (11-03-2018)
If Rottie is still a member here, he compiled all RPO codes for 1996 Corvettes. I have a hard copy of it. It has the code, description, quantity, cost and comments. If there is enough enthusiasm, I will digitally recreate it. By the way its 18 pages long. Email me at rcelli@hotmail.com, Regards, Ron
Originally Posted by Strick
GHO-- 3.54 axle ratio (On my 92 ZF 6speed) Always a good one to start an arguement.
(see? not starting an arguement!)
Originally Posted by bogus
I have emailed Mike Antonick on this one. I am curious if the RPO has been decoded correctly, or is the result of a typo somewhere down the line.
Like I said on the other thread: 1) it's on my window sticker as GHO--3.54 axle ratio, 2) It's on my build sheet as GHO--3.54 axle ratio, and 3) it's stamped on my differential. No, I'm not taking it out to count the teeth. I'll just have to live with the "Fabled Legend" Vette.
Originally Posted by Z-07 freak
These are worth putting on the list;
These are not;
These are not;
Please delete older threads! Wanna keep this neat!
My thinking is simple, I don't want people to think they need to read through pages and pages of posts.... it's all there!
Now, with that in mind, did I get everyone properly credited so far?
My goal is to list the RPOs... limitations in presentation make more info too complex to display.
If I had the ability to add an attachement, perhaps an Excel spreadsheet would be neat, or an Access Database?
Location: Why are there squished peanut butter cups in my underware?
Here's my suggestions to label the following;
FE1 - base "soft" suspension
FE3 - "sport" suspension, w/`96 Z-51 only
FE7 - "heavy duty" suspension, w/ `84-90 Z-51, `91-95 Z-07
FX3 - adjustible shock absorbers "selective ride control" `89-95
F45 - adjustible shock absorbers "real time dampining" `96
Z07 - heavy duty adjustible suspension package, `91-95 (cpe. only)
Z51 - heavy duty suspension package `84-90 (cpe. only)
Z51 - sport suspension package `96 (cpe. only)
Z52 - sport handling package `87-88
ZR1 - special performance package `90-95 (cpe. only)
jeffreyallan1234 (01-24-2024)
RACE ON!!!
Oh... this is getting interesting!!!
An email exchange between Mike Antonick and me:
This is question has been a bone of contention in the Corvette kingdom for some time.
I have not been able to find any documentation of it in the Corvette Black Book (2003 edition) and I cannot find my copy of Cor-Vette Specs, 1984-1996 (I moved, it's in a box somewhere, of that I am sure).
The question: What gives with RPO GHO - 3.54 axle ratio (On 92 ZF 6speed)?
It this real? I have seen no documentation to support it's existance.
Thanks!!!!
Andy Bogus
PS: I am real...
Hi Andy:
GH0 is the correct RPO (GM corporate wide) for a 3.54:1 axle ratio. When we originally did the Corvette Black Book, it was our intent for the RPO listing to be those that were true options. In the case of a '92 6-speed, I believe the 3.54 axle was the only ratio available. What gets tricky is that some RPOs are GM merchandising codes. For example, the G92 code is for an optional axle ratio. But the actual ratio might vary with the transmission and body type, and the "build" code will reflect the ratio. For 1992, the G92 was strictly an option for automatics.
I just spoke with a customer in the UK who couldn't find the RPO in the Black Book for a European speedometer and wondered why it wasn't there. That and your query have me thinking about a comprehensive listing of all possible RPOs in a future Black Book. Not sure it's doable, but I'm going to take a shot at it.
Hope this helps.
Mike A.
Mike,
Thanks!
This is getting facinating.
There is a member on the Corvette Forum with GM0 on his RPO sticker, and his is a 92 6spd. I have a 92 6spd, but it's not got that RPO on the sticker, just G92.
You are going to force me to crawl under my car and see what is stamped on the differential casing!
Again, thank you very much! I think we may be on to a mystery here! Time to dig deeper!
Andy
Thanks!!!!
Andy Bogus
PS: I am real...
Originally Posted by Mikes Reply
Hi Andy:
Hope this helps.
Mike A.
Originally Posted by My Reply
Mike,
Thanks!
Andy
lolmans34 (03-28-2019)
GH0 3.54 was used on early `89 ZF6-speeds, then replaced with GT7 3.33 for `89 &`90 L-98 ZF6-speeds.
I have seen a build sheet for an `89 ZR-1 (prototype) with the GH0 3.54 rear axle.
Strick is the only one I know of to claim to have a GH0 3.54 ZF6-speed with an LT1. He says the window sticker, build sheet and stamp on the differential verify this, then I'll take his word.
Is it an early production number? Maybe the designers decided this "lower" gear would work better with the LT1s specs? Are there any other `92 manuals with this gear? Maybe it fall under the same rareity of the `67 small blocks that received big block hoods from the factory for about three weeks because of supply shortages?
you may be right.... perhaps they Dana simply sent 3.54's as a mistake... then corrected it with 3.45's.
but I would think a gear change would require EPA recertification.
Okay guys, here is my vin# 1G1YY33P3N5105267. So I would guess that with it's plant sequential number of 105267, that it was an earlier built Vette in the 92 run. Also for Mike Antonick, use it for research. Do you want a picture of my differential? I'll have the exhaust off this weekend and a clear shot at the engraving.
When and why it was offered.
if it was an option, is there a price associated with it?
I am going to check mine and see what it really is!!!
I am no longer denying the existance of the gear... what we are now trying to figure out is the scope.
that is possible... very likely, knowing GM, but wouldn't that require another EPA test?
I checked the Corvette Article archive.... according to the 1992 road test from Car & Driver, EPA was as you stated... and their car was a 3.45 car.
