Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C4 Corvette Discussion not covered in Tech
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-07-2004, 01:09 PM   #1
teebee
CF Senior Member
teebee's Avatar
Default jacking up the Vette
I am learning as much as I can about my vette. I am a DIYer so want to be able to do as much as possible myself. What about all the talk about jacking my car up? Is there a problem with how it is done? How about using a two column lift (I have access to one where I work). Where are the best locations to set the lift points? Right at the regular jack locations?
I've read where you need to open the doors, hood, rear hatch, and then I read "Don't open" or it doesn't matter. Sorry about the length of this post, but I don't want to screw this up.
teebee is offline   Reply With Quote
Old 09-07-2004, 01:29 PM   #2
bogus
CF Senior Member
Send a message via Yahoo to bogus
A lot depends on the year of your Vette. The early C4s were not as structurally sound as the later ones.
I would leave the top in, tho.
lifting on the jacking points is ok, but the best place is just inside the frame. If you crawl under a little, and look just inside the jacking points, you will see where several seams converge. These points are VERY strong for lifting. Make sure at the rear you don't pinch either the fuel lines (pass side) or brake lines (driver side).
Opening the hood and the doors won't hurt.
Good luck!
bogus is offline   Reply With Quote
Old 09-07-2004, 01:47 PM   #3
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
When I swap DRs & streets I use the two rear jacking points and the stock jack.
I open the hood, the hatch, the doors and loosen the top. I've heard that jacking one side with the top secure can over stress the windshield.
__________________
My 1988 Z01 #65 Site
65Z01 is offline   Reply With Quote
Old 09-07-2004, 01:57 PM   #4
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Support Corvetteforum!
Mr Mojo's Avatar
Send a message via ICQ to Mr Mojo Send a message via AIM to Mr Mojo Send a message via Yahoo to Mr Mojo
I've jacked my car up with a floor jack on one side, floor jack in the middle(front) floor jack at the rear, scissors jack at the sides, two post lift,ramps, you name it. Never had an issue ever.
Mr Mojo is offline   Reply With Quote
Old 09-07-2004, 03:35 PM   #5
Frizlefrak
CF Senior Member
Frizlefrak's Avatar
Quote:
Same here. In fact, I've even inadvertently had the car "balance" itself on 3 jack stands (I didn't leave it like that, of course). Point is, these cars are a hell of a lot more rigid than they're given credit for. The frame rails near the jack points are very strong, and I often jack at the jack points and put the stands under the frame rails. The same can be done in the rear. Just always shake the car vigorously prior to climbing under it.
Frizlefrak is offline   Reply With Quote
Old 09-07-2004, 04:10 PM   #6
yellowlust
CF Senior Member
yellowlust's Avatar
I jacked up my 95 Vert yesterday. Placed the jack right behind the front wheel. All the way up it was on one wheel. Put jack stands at the front (not level as I need to get to the clutch slave) and lowered it back down. Good couple shoves to make sure it was sturdy and opened the hood and driver's door, no probs.
yellowlust is offline   Reply With Quote
Old 09-07-2004, 04:15 PM   #7
TaylorMutts
CF Senior Member
TaylorMutts's Avatar
Send a message via AIM to TaylorMutts
In the book "101 Projects for Your Corvette" (or something like that) by Richard Newton, he recommends that the C4 be lifted via a floor jack at a point halfway between the front and rear wheels. This allows you to lift the whole side of the car with one jack. You can then place a jack stand at the lift points right behind the front wheel and right in front of the rear wheel. I've done this many times with a 3 ton floor jack. Just be careful where you place the "saddle" of the jack--damage can occur to the bottom of the rocker panel and/or the brake line. Luckily, I do NOT speaf from experience on that one!
TaylorMutts is offline   Reply With Quote
Old 09-07-2004, 09:56 PM   #8
FOR PLA
Junior Member
I always jack it up in the center and place jackstands at the marked jacking points. Works great
FOR PLA is offline   Reply With Quote
Old 09-07-2004, 10:26 PM   #9
FlyboyZR1
CF Senior Member
FlyboyZR1's Avatar
Quote:
That's what I do to get the whole side in the air, works great ... and put a hockey puck on top of the jack.
FlyboyZR1 is offline   Reply With Quote
Old 09-07-2004, 10:30 PM   #10
rws.1
CF Senior Member
rws.1's Avatar
I have also jacked the front end using a floor jack under the front cross member and at the rear using a C4 EZ jack under the differential.
These give me the options of having the front jacked or the rear jacked in addition to the previous posts which let you raise one side or the other
rws.1 is offline   Reply With Quote
Old 09-07-2004, 10:33 PM   #11
fsr402
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
fsr402's Avatar
Send a message via AIM to fsr402 Send a message via MSN to fsr402 Send a message via Yahoo to fsr402
I had an exgirlfriend who's brother had a 86 with a glass top, he jacked it up and cracked the top. After that he would remove the top before lifting it. Me on the other had have had the Ruby setting on two jack stands one on the passenger side front and one on the drivers side rear and no problems. I would not tell anyone to do that, nor would I do it again.
__________________
1993 40th Ruby Red, K&N, open air, 160 thermo, tb-bypass, Corsa, D44-3.73's, 100 shot NX kit, lowered 1.5", EM long tubes, 1.6rr's, custom chip by PCMforLess,TransGo shift kit and 2800 stall
GOOD DEALINGS WITH.....
CorvetteSS,98silverC5,66vette,Jeffvette, Karshop, Da-Cajun,fullboogie,ERICVONHA,capkwk,Widebo dy, FLYNGUN,T1Kilr,abrimberry,Blown 96,tythor,Bruce,MrNuke,Corvetteronw,Ibuy vettes,89corvetteken,Renew
fsr402 is offline   Reply With Quote
Old 09-07-2004, 10:49 PM   #12
teebee
CF Senior Member
teebee's Avatar
OK, so what about the 2 post lifts? So far Everyone is referring to floor jacks (which is good that is what I have at home) but where should I place the 4 lift points on the 2 post lift we have at school? The similar locations as the floor jacks, I just don't want to screw things up!
Old 09-08-2004, 01:32 AM   #13
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Corvette Kid's Avatar
Location: Islam - Contributing not one damn thing to humanity for 1400 years
Ditto.... and I have to question, why would one find it necessary to open the doors, hood etc.? If they are worried about the rigidity, this would seem counter-productive. Not that there's any problem on C4s with opening a door and closing it again while jacked up, unlike earlier Vettes.
Corvette Kid is offline   Reply With Quote
Old 09-08-2004, 02:34 AM   #14
skateparkdave
CF Senior Member
St. Jude Donor '05-'06
skateparkdave's Avatar
also, I too have the Richard Newton book and this works great.
skateparkdave is offline   Reply With Quote
Old 09-08-2004, 11:16 PM   #15
howdo
CF Senior Member
Default my 2 cents on the newton method
I just tried the "Richard Newton" method of jacking the whole side of the car up. For me, it didn't work so great. Basically, the hydraulic jack deformed and bent the frame rail (right below the middle of the door). Not a big deal, but bad enough where I wouldn't do it again. I saw the other posts mentioned a hockey puck, but Newton didn't mention this in his book.
How do you use the puck, do you cut a slot to allow the frame rail to sit in it?
howdo is offline   Reply With Quote
Reload this Page jacking up the Vette
Tags
1988, 2004, 40th, corvette, differential, garage, jack, jacking, jacklng, polnts, red, ruby, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
