coupe vs convertible
Old 08-02-2004, 04:53 PM
exlration
exlration's Avatar
Default coupe vs convertible
do they drive differently? I know the coupe drives differently depending on whether the top is on or not. does the convertible drive like a coupe with the top off or possibly worse?
thanks guys
michael
Old 08-02-2004, 05:28 PM
byte_me
byte_me's Avatar
thanks guys
michael
Well coming off an 84 Z51 coupe to my 94 Convert- I can say that the car feels every bit as solid as the 84 (not as harsh)- but much more refined! The vert's have a cross brace under the car that goes from (roughly) each jack point criss-crossed under the car...it stiffens the frame to deal with no top. The older C4's seemed to be a little ruff around the edges compaired to the later versions (no rubb against the older c4 guys) I guess it all comes down to preference really- but if you are looking for a road racer...you may want a coupe...only because it has more frame up-top....
but I would go for a vert myself- it is beautiful to go topless :-) ladies???
Old 08-02-2004, 05:45 PM
VenkmanP
VenkmanP's Avatar
Vert is definitely more solid than a topless coupe, because of the cross brace.
Vert is probably looser than a coupe with the top in, but not sure.
Vert with hardtop would probably be more solid than a coupe with the top in.
Old 08-02-2004, 05:47 PM
exlration
exlration's Avatar
Default thanks
I will go with the vert!
Old 08-02-2004, 06:38 PM
Strick
Strick's Avatar
I have the 92 GM video on the Corvette. Did you know that the vert has a lower center of gravity than the coupe? True. If you put a camber-brace and a cross-bar in, your vert will out corner a coupe, all other things being equal. BUT, if you want to race, the vert needs a roll bar if you get serious where a coupe might not need one as fast. Still, there is nothing like cruising at night with the top down. I got it, buy 2, a coupe for racing and a vert for cruising. Simple.
Old 08-03-2004, 03:38 AM
mitymek
mitymek's Avatar
verts heavier.go to slow.
Old 08-03-2004, 09:17 AM
corvetteronw
Support Corvetteforum!
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Have a go at this vert with your coupe!
Old 08-03-2004, 09:21 AM
Stv50
Stv50's Avatar
Convertible of course.
Old 08-03-2004, 09:42 AM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
When Pratt & Miller start building their cars in convertible form, I will consider a vert. ..maybe.
To me the Corvette is about performance above all else. You can profile with the top down all you want if that is your preference, but I like the image of take-no-prisoners speed...and that means 'coupe'.
Larry
Old 08-03-2004, 10:24 AM
jerkyboy
jerkyboy's Avatar
My 89 vert top down is stiffer than my old 92 with top out.
With my hardtop on, it is much stiffer than the 92 with it's top on.
I don't know about a lower center of gravity but the vert's suspension was raised compared to the coupe to clear the x brace hanging down. I took care of that little issue too.
Old 08-03-2004, 11:43 AM
c4cruiser
c4cruiser's Avatar
I have one of each. My 87 Z52 coupe is stiffer (even when the suspension was stock) but when you remove the top, there is definite cowl shaking that I don't really see in my 92 vert. The vert is prone to more twisting simply because of th lack of the coupes targa bar but the X-brace on the vert helps to tame some of the twisting.
The vert's ride height is higher than a coupe in order for the vert X-brace to have the same ground clearance as the coupe. Depending on the year, verts may also have different spring rates than coupes. But earlier C4 verts also got the same frame stiffeners that werre installed on Z51 and Z52 cars.
But put a factory hardtop on a vert and the whole picture changes! My vert with the hardtop is much stiffer than the coupe. All of the typical squeaks and rattles that are usually associated with verts completely disappear. My 92 vert felt much stiffer than my 87 coupe at least until I added a camber brace, cross-bar and Z51 shocks and poly bushings.
So yoou might get a vert and add a hardtop and you will have a great-handling car with the hardtop on and cruise in the sun with the top down.
Old 08-03-2004, 05:01 PM
Marlin in Minn
Marlin in Minn's Avatar
Depends on whether it'll just be street driven or if you'll want to take it to the track. My vert spent the first 9 years of its life as a weekend cruiser. Now the only mileage it sees is at the race track. Like Strick said, you can race the verts...but it will cost you more money in safety equipment..
Old 08-03-2004, 05:20 PM
oldace84
oldace84's Avatar
St. Jude Donor '04 & '05
Vert's are the Koooooolest.
If I could do it all over. A vert would be my choise!
Old 08-04-2004, 12:21 PM
Rocky Rothrock
Rocky Rothrock's Avatar
As stated before..nuthin beats gettin blown in a vert
Old 08-04-2004, 05:41 PM
TD-Machines
TD-Machines's Avatar
Old 08-04-2004, 08:07 PM
lb33knight
lb33knight's Avatar
Verts!!!!
Old 08-04-2004, 08:25 PM
VenkmanP
VenkmanP's Avatar
That extra 60 lbs is a killer.
Old 08-05-2004, 08:45 AM
SilverBeast
SilverBeast's Avatar
St. Jude Donor '05
My '96 CE is like a rag doll with the top off! I made a post about it and found X-brace for $300 bucks, but don't have that kind of cash yet. I'll definitely put it on, (maybe Santa will bring me one!). In the meantime, when the top is off the vert rules for body stiffness.
Old 08-05-2004, 09:00 AM
F1Fan
F1Fan's Avatar
Here's my opinion...
I've got a '95 coupe, with cross bar, camber brace and the vert x-brace. It's not bad, but my '99 SS (Camaro) feels 10x more solid. Granted it does have the subframe connectors and shock tower brace, but there is no comparison which is a more solid car. Not one squeak or rattle, ever.
The vette has never been damaged. The small amount of shuddering I still experienced when I took the targa top out was dissapointing and unacceptable to me. I won't drive it with the top out anymore
If the 'verts are worse, I don't think I could stand it!
To coupe vs convertible
Quick Reply: coupe vs convertible
