Installed Magnaflow's today!
Location: Sunny Seaside Seabrook Texas (a whole 'nother country)
1 Post
Originally Posted by Darkgh0st
The resonance problem is WAY overrated. You might have slight resonance if your engine is highley modded, even then you can fix the problem with an X pipe or sound deadening material under the carpet behind the seat.
I can hear the exhaust inside the car plenty, but if I didn't want to hear the exhaust inside the car I wouldn't have put them on. It amazes me when people take the quiet stock exhaust off and then bitch about how loud it is in the car after they put on aftermarket mufflers
Can the resonance problem be (somehow?) year specific?
(enjoy 'em, Tim!)
Originally Posted by eptaylor
[FONT=Arial]did you get cat back or just two mufflers for 350? If just mufflers what part number? They are just listed as universal fit on the website. Thanks
just the two mufflers. if i'm not mistaken the 92-up already has 2 3/4 or 3" pipe already, so there is no need to upgrade from the cat back. the part number is i believe 15623. on the website go to the search box and enter the part #. don't forget the coupon!
randy
theres pipes with your year,all the way to the cats. try a search for 15658 at www.hottexhaust.com
dont forget to enter the vetteforum in the coupon area on checkout
for a total of : Sub Total: $541.58
Coupon Discount: -$81.24
Sub Total: $460.34
im betting on your 90 you'll see some performance difference going to true duals.think its just noise on the later models.(and looks)
I've never had a car with a modified exhaust before, so when I put the Magnaflows on my car, I had what I thought to be horrible resonance.
Then I realized what I was hearing was all the loose trim vibrating in the rear of the car. Two minutes with a screwdriver, tightening up the trim in the rear, solved the problem for me.
(LT1 system is Part Number is 15623)
The Hottexhaust.com website has layout that is difficult to navigate. Just type "corvette" in the search to find all of the Corvette muffler systems.
Make sure you use "vetteforum" as a coupon code to get your discount.
Sub Total: $541.58
Sub Total: $460.34
Total price for the L98 Catback system = $460.34 including shipping
