"Service Ride Control" light on DIC...
Is the "Service Ride Control" light in the DIC suppose to light up when you start the car. Can't find anything definite in the service manuals. I'm thinking that it should and that I just have a burnt out bulb. Thanks, Zane
Re: "Service Ride Control" light on DIC... (94redrag)
The SRC light will light when you turn the ignition switch to Run and then go off when the car starts and the SRC systems completes a self-test.
So you either have a light that is burned out or a previous owner had removed the bulb after finding a problem with a shock or actuator. You'll have to have a working bulb if you are going to check for any codes by yourself.
Re: "Service Ride Control" light on DIC... (c4cruiser)
Thanks Guys! I was pretty sure that it was supposed to light up and do a self test at start up, but just wanted to confirm. Looks like I'll be tearing into my console/dash once the weather warms up a little. Its a shame you have to remove so much stuff just to change one little light bulb. Later Zane
