C4 exhaust manifolds and a Camaro? Will it fit??
Received 1,424 Likes
Re: C4 exhaust manifolds and a Camaro? Will it fit?? (tworottiedogs)
Theyll bolt to the heads, but dont dump/collect in the same position.
I don't think it would work because the F bodies sit their engines a lot farther forward related to the front suspension than the vettes do, so their exhaust manifolds have to exit more toward the back instead of in the middle like the vette's
1 Post
Cruise-In X Veteran
they will bolt up,...but you will ned a custom y-pipe to match. not worth the trouble imo, get a set of used headers with a y :thumbs:
What years, engines?
If you are talking about LT1s then no way. I have a set of both manifolds because my LT1 is an F-body trans plant and the manifolds are completly different. The bolt patern for the heads is about the only thing the same. The dump location, EGR tube location, and air fittings are compleatly diferent.
Re: C4 exhaust manifolds and a Camaro? Will it fit?? (84LT1)
I believe no matter what year camaro you have, ultimately the y-body manifolds will dump right into your K-member. Even if they physically fit, there won't be room to attach a y-pipe.
