Do headlights hurt mileage?
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Just got home from a 1500mile "run" in the Assassin.
Early this morning, on a long, flat straight in Utah, I put the cruise control on 80, (with the lights on) and noted the instant mileage readout. I then turned the lights off, expecting the improved aerodynamics to come into play and see a slight increase in mpg. To my surprise and horror, the instant mpg DROPPED from 31 to 27! I turned the lights back on and the readout instantly went back to 31....even before the lights flipped up. Back and forth I went...each time turning the switch on or off affected the mileage readout.
Anyone else had this happen??
Larry
code5coupe
:seeya
Larry
code5coupe
:seeya
Elite Torch Red Member
Re: Do headlights hurt mileage? (rocco16)
That's wierd, we tested my friends Celica, with teh headlights down he could go 5 mph faster.
Location: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
Maybe its breaking up that bad low pressure zone at the base of the windshield Ive heard about. Odd about the mileage as mines always almost 40 mpg till I hit about 90-95 mph. :D
Re: Do headlights hurt mileage? (vinnies87)
It shouldn't make a noticable difference one way or the other. Maybe the added load of the headlights is dropping the system voltage enough to affect the computer. Have you tried running with the headlights up, but not on?
:cheers:
:cheers:
Cruise-In II Veteran
I only notice a slight drop in mileage with the top off, but headlights up/down don't seem to effect the readings.
I too suggest you try the test with headlights up/down but off, as you may have a voltage or grounding "gremlin" aboard.
going up a slope vs. going down a slope has a lot more to do with the gas milage then the aerodynamics caused by head lights.
Well from a theoretical view turning headlights on takes power. The only place this power can come from is the motor & the gasoline that powers it, so from that point of view you should expect lower mileage with headlights on.
The aerodynamics of the raised headlight would intuitively increase "drag" and thus reduce mileage.
On the other hand, both these effects would be "small" so a difference would be hard to isolate. For example two 55 watt headlights total 110 watts. I think 1 hp is 776 watts or there abouts, so it really doesn't make much difference.
Personally the first time I ever heard about headlights effecting car's performance was in about 1959 when I, as a teenager was on day trip with a friend and his Dad, a mechanical engineer, who said that we would get less gas mileage on the way home from this trip since it would be dark & lights would be on.
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Re: Do headlights hurt mileage? (Mr Mojo)
Location: Minnesota in the summer, Las Vegas in the winter
Perhaps what you thought was the headlight switch was actually known technically as RPO AAD:
Automatic Anchor Drop.................. :rofl:
Re: Do headlights hurt mileage? (65Z01)
I'll try the headlights up/off next time out.
I expected a betterment in mpg with the lights off, not the opposite. My gut tells me there is an electrical gremlin loose, since no one else reports a similar occurance. No other electrical anomalies though.....
Sidebar: In 1500 miles of driving over two days, I saw exactly TWO Corvettes on the road (one C5, one C4)...no Mustang Cobras, no Vipers, one 911 with which we "flew in formation" for an hour or so. Minivans by the hordes, Camry's by the dozen, and a surprizing number of Olds Aurora's. Where are all the performance cars?????
Larry
code5coupe...the Assassin
:seeya
Larry
:seeya
if you were that worried about gas mileage, you should not have bpught a vette
i'll gladly take 27mpg... seeing as i usually get about 15
Actually they do.....but it's so small you shouldn't even notice until you're doin about 90-100 mph. The ECM's just trying to compensate for it. Notice when you fill up a tank how it will never really show it as full all the time. The ECM tries to compensate for so much that I have no choice but to question it's accuracy. It's accurate ENOUGH , but not 100 percent. The headlights thing is really just an aerodynamical physics issue, but I think the ECM is getting it's data from the weight distribution. Stock headlight lamps are glass I believe. If it's that much of a Big deal to you, try replacing them with some plastic lamps/lenses if you don't have em in already. It's alot less weight and therefore alot less weight that gets distributed to the front end when the lights flip. Keep in mind though I think it's like 60 percent lighter, but 60 percent of a pound or two is what you're dealing with at most if they weigh even that. Like I said though, performance wise it shouldn't make a difference unless you're constantly at high speeds. :steering:
Headlight weight, volts=hp, and headlight aerodynamics DO NOT significantly affect mileage like in this manner. You have an electrical problem which is the cause of the false reading.
*Something to think about: opening and closing the headlights at high speeds (or at any speed except for at a dead stop) HIGHLY effects the wear/life of the headlight rotation points. Never open or close your headlights unless you're at a dead stop. Bumps/jarring and wind resistance/pressure on the mechanism as it is rotating causes great wear.
Good luck, bro!
Good luck, bro!
Re: Do headlights hurt mileage? (Silver 96)
:cheers:
:cheers:
Re: Do headlights hurt mileage? (C-4 Cross Fire)
Good luck, bro!
Good luck, bro!
