Where to get rotors?
I have some pulsing in my brakes and think I may be in line for new rotors for my 86 vert. Recommendations? What can I expect to pay? I don't need an upgrade unless it doesn't involve changing anything else. Just looking for a good source. Thanks in advance.
Re: Where to get rotors? (Charlutz)
Check out http://www.iroters.com . I bought 4 cross drilled/slotted rotors for under $400.00 including shipping! :thumbs:
Re: Where to get rotors? (yoslambo1@cs.com)
http://forums.corvetteforum.com/zerothread?id=664380
Re: Where to get rotors? (Mr. Magoo)
You might want to check those rotors. :eek:
http://forums.corvetteforum.com/zerothread?id=664380 Thanks for the heads up....I definetly will keep an eye on them now. :smash:
looks like they do treat their customer well though................check this out. :cool:
http://forums.corvetteforum.com/zerothread?id=667118
Re: Where to get rotors? (Eric 96)
:iagree:
They had some really nice sales on pads and rotors. Don't know if it is still going on or not. Check them out!!
:cheers:
:cheers:
You can go through Mid America and you'll pay less than 90 per rotor for some decent ones for your 86. So they're right it'll be about 400 with shipping in most cases, but installation would be probably another 300 or 400 depending on whether or not you need em installed or are planning to do it yourself for all four rotors. I'd suggest the latter if you can. Are you feeling a gritty pulse when you brake? If so you're probably right...happened to me a while back and sure enough.... rotors.
Muskegon Brake gives great personal service: $49.00 each, they ship UPS.
Website: http://www.muskegonbrake.com
They work great on my '85.
Re: Where to get rotors? (MaSTeRofDZaSTeR)
St. Jude Donor '04 & '05
Corvette Central has a package deal for rotors (Drilled), with good pads.
Seems like a good deal to me. http://www.corvettecentral.com
Just my 2 cents.
Good Luck
tony
:flag
Just my 2 cents.
Good Luck
tony
:flag
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Never fear.
Brake work can be some of the easiest maintainence you'll do on your Corvette. I put new rotors (it was pulsing) and pads on and the hardest part was getting the front rotors off the hub.
Larry
code5coupe...the Assassin
:seeya
Larry
:seeya
