1 to 4 skip shift -- STOP!!
Old 07-09-2003, 12:54 PM
cicch95
cicch95's Avatar
Finalist 2020 C4 of the Year - Unmodified
Default 1 to 4 skip shift -- STOP!!
I read this tech tip...............
Submitter's Name: Don Hall
Email Address: donhall@cruzio.com
Corvetteforum.com Member Alias: oldman
For those of you experiencing difficulty with the 1 to 4 shift lock-out, or for those of you who wish to experience shifting through all your six gears, here is a simple fix: on the passenger side, just in front of the fire wall, and mounted on the fender well, is a relay, that when disconnected, will disable the 1 to 4 lock-out allowing you a very smooth shift transition through all 6 gears. Simply locate the correct relay (your shop manual will identify it); disconnect the relay; place a piece of styrofoam between the connections to prevent electrical contact and moisture absorbtion; reconnect the relay onto the fender well clip.
Just remember that you will always display an error code during a diagnostic check, so alert the technician, if your vette is in for repair, to disregard that error code for the 1 to 4 lock-out.
I have two problems.....1) I do not have a manual, can anyone tell me or send me a picture of where th relay he is speaking about actually is? 2) Do I need a plug to disable it or can I just unplug it like the tip suggests?
Any help will be appreciated....this skip shift is killing me! Thanks!
Old 07-09-2003, 01:06 PM
96LT4
96LT4's Avatar
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Default Re: 1 to 4 skip shift -- STOP!! (cicch95)
If you've ordered the CAGS eliminator, there should be a picture with it. If you haven't ordered the part, do so. :yesnod:
Old 07-09-2003, 01:09 PM
Gorgon
Gorgon's Avatar
Ecklers sells a CAGS eliminator for the LT1 6-speeds for $12. It will take a couple minutes to get under the car to install it. I would rather mess with that then the relay. Under the car on the driver's side of the transmission is a cable with a connector. You can basically unplug the connector and the CAGS will be eliminated. The kit just allows you to save the connectors from corrosion and has a tie wrap to keep the wire from hanging. I recently did this on my 95 vert and the only complaint I had was that I waited 10 months to do it. :cheers:
Old 07-09-2003, 03:20 PM
96CollectorLT4
96CollectorLT4's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (Gorgon)
I also just simply disconnected the connector at the tranny. Easy and it works!! :seeya
Old 07-09-2003, 04:34 PM
sundbergjc
sundbergjc's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (96CollectorLT4)
Get the CAGS eliminator. No warning lights and the disconnected parts are protected from moisture and dirt. Takes about 2 minutes to install (after jacking, that is). Don't crawl under there with only a jack holding it up.
Old 07-09-2003, 05:52 PM
LT-4 CE
LT-4 CE's Avatar
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: 1 to 4 skip shift -- STOP!! (sundbergjc)
YEP, :iagree:
Old 07-09-2003, 06:20 PM
96CollectorLT4
Default Re: 1 to 4 skip shift -- STOP!! (LT-4 CE)
Well I don't have any warning lights on, and I figure .02 cents of electrical tape does the same thing as a $16 connector. It would end up costing me about $40 with exchange, shipping, taxes, etc, etc. No problems so far....
Old 07-09-2003, 06:22 PM
JB666
JB666's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (96LT4)
Best mod I've done to date :)!!!!!!! :cheers:
Old 07-09-2003, 07:57 PM
mid life 90
mid life 90's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (Jbaker)
I use the heavy foot eliminator, no worries about dust or dampness, just the boys in blue :auto: :lol:
Old 07-09-2003, 08:15 PM
don hall
don hall's Avatar
....I do not have a manual........
cicch95, that tip is for 6-speed manuals........it does not apply to an automatic....
Old 07-09-2003, 09:21 PM
cicch95
cicch95's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (Oldman)
When I said manual "oldman" I was refering to the owner's service manual! All of the owner's manuals and any service manuals were not with my car when I purchased it last week!
Thanks to all for the advice!
-Rick
Old 07-09-2003, 09:51 PM
don hall
don hall's Avatar
When I said manual I was referring to the owner's service manual
Pardon me for being stupid (don't grow old)... :bb ........I will email you a pic of the relay location. Your '92 should be the same as my '93.
Old 07-09-2003, 11:08 PM
don hall
don hall's Avatar
Pic sent......let me know if it is readable.
Old 07-10-2003, 02:15 AM
radwebster
radwebster's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (mid life 90)
:rofl: :rofl:
Old 07-10-2003, 08:33 AM
bac22
bac22's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (radwebster)
Just don't shift until you hit 20 MPH, problem solved.
Old 07-10-2003, 08:34 AM
cicch95
cicch95's Avatar
Got it and thanks!!! Oh and there's nothing wrong with being "old" unless you become a couch potato!!! :flag
Old 07-10-2003, 01:06 PM
CLoNE
CLoNE's Avatar
Default Re: 1 to 4 skip shift -- STOP!! (bac22)
:iagree:
To 1 to 4 skip shift -- STOP!!
Old 07-10-2003, 01:09 PM
JB666
JB666's Avatar
That works, unless you have a 157 year old woman in front of you in a Ford Escort, and you'd like to blow by her in 2nd, and can't cause you were forced to jump to 4th. I had a problem with it only because I like to control when I shift, not when GM FEELS I should be shifting... Best $10-15 I've spent!!
Old 07-10-2003, 07:11 PM
JWG
JWG's Avatar
St. Jude Donor '07
:iagree: ..................that works for me.......... :D
Old 07-10-2003, 07:17 PM
Rex Ruby
Rex Ruby's Avatar
Philly 'Burbs Events Coordinator
Default Re: 1 to 4 skip shift -- STOP!! (JWG)
I did mine at the ECM:
On your ECM, A connector block (gray tab) disconnect A-9, the white wire (circuit 375). This controls the dash one to four indicator light. On connector block B (red tab) disconnect B-2, the dark blue wire (circuit 1493). This controls the solenoid at the transmission. Remove these wires and pins from the connector. It's easy to reconnect :cheers:
Quick Reply: 1 to 4 skip shift -- STOP!!
