1984 Trans problem
1984 Trans problem
1984 Vet, 75,000 miles. While driving at approx. 75 mph a loud rapid clanking noise sounding like it was coming from the trans area. This clanking noise continued till I pulled over and stooped the car. While on the side of the road, put the trans back into Drive and the clanking noise clanked slowly as I moved forward.
Stooped the car and put the trans in Reverse and moved slowly backward
with no noise. Now, selecting Drive again and pulling forward, there was no
noise, I pulled slowly back on the the road and ended up resuming normal hwy speed with no further noise. I drive this car regularly and have never heard this noise again until yesterday, exactly the same thing, after selecting Reverse and then again Drive, received no further noises and resumed regular hwy speeds. Universal joints were checked and are ok. I cant rule out rear end as the noise was hard to pin point.
Does anyone have any experience in this area, I think the trans is original and is a 4x2. Many thanks, great site for great information. Dave..
Re: 1984 Trans problem (Captn)
High pitched clanking noise? Dull sounding or bright sounding?
It might be the parking pawl getting in the way...
It might be the sound of a cracked driveplate, or a blown torque converter...
You might have caught a rock and carried it around under the dustcover for a few miles...
<shrug>
:seeya
<shrug>
:seeya
Re: 1984 Trans problem (Matt Black)
It might be a craked flexplate, pull the inpection cover and use a flexplate tool (or a prybar) to crank it around by hand(not in park) and try to pry the edge of the flexplate away from the converter in spots around the perimeter as yo look for cracks . Youll see it if its bad. Its an easy enuff check, worth a shot. I hope its something simple. :steering:
St. Jude Contributor
Sounds uncomfortably like my problem, ended up bein my rear diff was shot
It was a scary thud thud thud thud. Hope this is not your problem, thought its always a good reason to upgrade!
St. Jude Donor '04 & '05
This is something new to me....I've got 87k on mine...and never had any of these type of problems...
Since you posted.....has it happened again??????
Let me know...
thanks
tony
:flag
Let me know...
thanks
tony
:flag
