Wheel Bearing Manufacturers?
OK,
Checked into wheel bearings from local parts shops.
Autozone - Timken $169
Advance - BCA $168
NAPA - NAPA $227
GM Dealer - GM $448
GM Parts Direct - $228 + $44 S/H = $272
Has anyone had any experiance with these different manufacturers, the GM dealer unit is looking way out of line on price?
Advance - BCA $168
NAPA - NAPA $227
GM Dealer - GM $448
Re: Wheel Bearing Manufacturers? (Dolfan)
i got mine from pepboys for 149 with a lifetime warrenty. I dont remember the brand off hand.
[Modified by n1kki6, 2:48 PM 2/24/2003]
From personal experience, get the GM ones. I put two sets of the cheap ones on in three years. That's actually more than one set of GM. They were 269 from Mid america.
Re: Wheel Bearing Manufacturers? (Redhot84Z51)
RedHot,
Do you remember what brand of "cheap" hubs you used?
Timken? BCA? Chicago Rawhide? Other?
I'm curious I'd like to make an informed decision if I deciside to save the money.
My story may help you out
http://forums.corvetteforum.com/zerothread?id=411898
Re: Wheel Bearing Manufacturers? (chucks88)
chucks88, Thanks for the related story. I'm looking into the fronts only right now. Didn't look like you were dealing with the front but the rear only but does present some questions on the manufacturers.
I on have 68K on my ride but now have about 10 autox sessions on the car and I know that is stressing things like this that might go longer with normal driving.
But then again what is normal corvette driving :D :cheers:
Thanks for the perspective from your experiance.
Call Jeff Kopp at Superior Chevrolet, he'll give them to you for about the same price as GMpartsdirect with lower shipping.
Jeff Kopp - (800) 728-8267
Or parts@superchevyperformance.com :thumbs:
[EDIT] Make sure you tell him you're a Forum member to get the discount [/EDIT]
[Modified by VetBoy89, 3:27 PM 2/24/2003]
Hey,
I'm just curious as to how you can really tell that a car's wheel bearings are on their way out. Obviously, most of you just replace them as a rule of them when it's convenient at a mileage of your choosing, but I was wondering what effects bad bearings would have.
Squeaks? Chirping noises with wheel/tire rotation? Has this ever happened to anyone? Reason I ask is because I have an annoying chirping noise coming from the rear, and I believe it to be on the left (drivers-side). It increases in speed as speed increases, so I know it's something on the driveshaft(s). :confused:
Lemme know, thanks.
Lemme know, thanks.
Re: Wheel Bearing Manufacturers? (Igniter)
First off............Welcome to the forum.......there is no turning back now.
For a bearing test, get the rear tire off the ground, grab the tire at 12:00 and 6:00 and rock it to see if there is movement. I am not talking about the movement from the suspension but a distinct up and down movement. It may only feel like it moves a .031 or so. any movement is not good. how old is your car and how many miles?
Re: Wheel Bearing Manufacturers? (robertpel9)
When you are checking for bearing wear, make sure you are getting bearing movement and not ball joint movement.
1 Post
Hey,
Lemme know, thanks.
Lemme know, thanks.
