United radio for digital instrument panel
Just a question for the group. Has anyone used United radio in NY for digital instrument repair?
My 87 has 4+3 and has no overdrive display. I got in touch with Batee and they are quoting $500+ to get the right boards and refurbish it. In June 2000, it was repaired by United radio that obviously used the wrong boards out of an 1985. United radio has offer to repair and fix it. Not sure I trust them because everyone says to use Batee.
It won't be $500
https://www.ebay.com/sch/i.html?_fro...r+87&_osacat=0
What makes you so sure UR used incorrect boards? It worked how many years after the UR repair? What is your relationship to the owner in year 2000 when you say UR repaired? Do you know for a fact that this was a UR repair and verified by VIN? Maybe a previous owner bought a used that had been previously repaired? You seem to be assuming much!!!!
United Radio quoted you how many $$$?
I’m assuming that this thing hasn’t been taken out a bunch of times. It does have a repair sticker from June 19, 2000 from United Radio. I was surprised that they were in business and someone answered the phone. I’m just trying to see if it is worth my time to send it to them.
There's a CF member that does pretty reasonable cluster exchanges and I believe also has an eBay presence. You might reach out to @scarabexc and see if he can help you with a correct for your car and maybe some $$$ for what you have now. Early clusters I believe he does pretty well.
United Radio has been around for years. They install the radio's in most of the police department departments around here. I've had car radios repaired there previously and was satisfied with their work. I know they also do gauge repair but never knew they also tackled Corvette gauges.
If you're so sure that it has incorrect parts in it then I believe it's very foolish to send it 'as is' and expect a reliable repair to maybe any of the conventional shops. You might tell them what you suspect is incorrect and if they offered an estimate before proceeding maybe you send it and let them. Can they supply the parts that you suspect are incorrect? You've got a quote you say of 500$ from Bryan so I'd say you've enough information to make a rationale decision based on a conversation.
There is no difference between manual and automatic transmission gauges just cruise and no cruise.
