Stuck seat belt receiver 1995 red button
The female end of my seat belt- the buckle, latch or receiver, is stuck “closed” and won’t accept the male end. I can peek down into the latch and it looks like it’s in the buckled position. Pressing the red release button has no effect.
I was thinking of trying a spray lubricant to loosen the mechanism. Anyone had this happen and been able to fix it?
Thanks for the reply. I was able to fix it with a flashlight and small flat screwdriver. There was just some built up lint, dust, etc in the release mechanism. I held the release button down and gently opened the mechanism with the screwdriver. There are a zillion vids on YouTube on this topic and most recommend a little spray lube but some say it isn’t needed. I’m glad I didn’t need it, I was a little worried about getting it on my clothing later. Problem solved.
C4 Steck (03-25-2024)
Glad that worked out for you. And good info here in case it happens to anyone else.
