1995 motor swap to 1985
If I swap my LT1 from a 95 to a 1985 zr1 will it plug and play or?/ Do I need to rewire the 95 harness to the 85? I've got an 85 zr1 getting shipped and my 95 just blew a connecting rod bearing. So rebuild is coming but the 95 is in rough shape no dash, suspension shot, was wrecked has Bondo hiding stuff I've discovered recently before motor decided to send it last night.
Basically need to know if I need to swap over accessories or harness or computer from the 95 to 85 when my motors rebuilt. The zr1 motor will get built afterwards or go into a zr1 that's got no engine.
Thanks in advance
Thanks in advance
An 85 ZR-1??? ZR-1’s were built from 90-95. New member, so you’re either a troll or you just don’t know. Do explain.
Are you for real? There are so many red flags 🚩 with your post this has to be scam
