Should be about to pull it out, try using some type of lube and twist while pulling. If it breaks it looks like a replacement is available at least. Good luck.
Since the booster is cracked, im going to cut it out wirh a dremel
That's a good plan but before you do, you should start a thread that asks "Does anyone know if it makes a difference what type of cutoff wheel I use in my Dremel?"
