Question about bypassing the vats
I'd like to bypass the vats on my 96 and the resistor on my key is 1.86 ohms. I went to a few electronic stores and they don't carry a 1.86 resistor. They sell resistors with different ranges. So I'll have to buy a few and wire them in series to get close to 1.86. Does the resistor value need to be on the spot of 1.86 for this to work?
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
No.
I just did mine a couple of weeks ago.
Mine needed to be 1.46 and I was able to find a 1.46 resistor.
But, yeah, you can double em up if you have to.
I had the same ''range'' question that you had, and a lot of helpful folks chimed in when I asked about it.
Looks like yours is #7. So anything in a range between 1795 and 1965 on yours will crank it over.
Here's a chart that was shared from that thread...
RPO Joe (10-27-2023)
It's worth remembering that there is starter kill, and also an injector kill. The injector kill has to be bypasses via the ECU.
https://www.newark.com/w/c/passive-c...=1.87k&gs=true
Terminology is important in electronics. They are not 1.86 they are 1.86k (or in this case 1.87K).
Get one of the 400mw or 250mw through holes. https://www.newark.com/yageo/mfr-25f...K5955?st=1.87k
i bought a set of resistors from amazon a couple of weeks ago it has a few of each key resistance didn't cost much haven't had a chance to do mine yet my back is out and i can't get in it to do it
Just an.idea to eliminate the common failure and keeping vats. Typically one of the 2 little wires keeping compromised at the lock cylinder over time. You could get replacement cylinder mount it somewhere under the dash install and old key in it, Cut cheapie steel keys for use. If car is parked for extended periods of time or unsecured location; pellet key could be removed causing vats to operate if unauthorized users try to take car. To really get around vats it needs to be turned off in the pcm programming.. (prom)
The following 2 users liked this post by ChumpVette:
1985 Vette (10-29-2023),
Natty C (10-29-2023)
I am kind of casually keeping an eye out for a lock cylinder and key with the right resistance so I can redo it right, though.
I don't know how or even if that cylinder can be taken apart, else I would go that route and repair the break that way.
You know this, but I'll point it out anyway: You don't need the correct resistance key with the replacement cyl. If the key that comes with the cylinder operates it, that key can be used to cut a key with your Code that matches your car. My local key shop charges me $18 for a GM VATS key. Not too painful.
