New Starter Burning Smell
Hey all.
I Installed a new high-torque starter in my 1985 2 days ago, and I'm noticing a bad smell whenever I have the car started or generally in the garage. Temperature has dropped from the usual 70 to around 50, and the car was on jacks for about 2.5 days while it dropped.
I'm wondering if this could be melting wires if they are too close to the exhaust manifold or block on the passenger side or even something electrical if the push-on terminal was not seated correctly. Maybe just a new starter smell?
Smells similar to the exhaust, but it's hard to tell. Sniffing around in the engine bay has less smell than outside the front or rear of the car.
Lord
Lord
This appears to be a pinched hot wire.
Or developed a breech on the wires jacket.
I would suggest thoroughly inspecting your stater / solenoid wires.
Before you direct short the battery.
I don't think there was any damage sustained to the wires, but I will check. The smell doesn't seem to be coming from the starter/effected wire area, though.
Thank you.
Lord
Received 3,043 Likes
St. Jude Donor '05
You said stronger smell like exhaust behind and outside the car.
Smell like gas or burning oil? Any drips on the ground the next morning?
Its common for the seal between the back of the intake and the block below it (china wall) to seep
It slowly runs down the side of the block and can drip on your exh pipe under the manifold.
Could be the stink after you park it...maybe a droplet or two burned off.
In the morning when you start it that pipe gets super hot and burns the oil off. Could be your mystery smell.
If you stand (with hood up) next to the engine drivers side and look for the pipe below the exh. manifold exit do you see
some black on the pipe anywhere?
The fix is to remove the intake manifold and reseal Let it sit overnight before starting so the sealant is cured
Thank you.
Lord
St. Jude Donor '05
Added more to my post above yours. Does your gas cap whoosh when you remove it?
No fuel leaks where the 2 steel lines mount to the (pass side front) intake manifold...nothing around it, the rear?
Gas is something to pinpoint asap Weather shouldnt change anything
Much abliged.
