96 wont cold start
96 wont cold start
Just bought a 1996. Drove it home 4 hrs and even drove it yesterday a few times. Tried to take it to work this morning around 6:30am and engine wouldn't turn over although it does crank. Tried to jump start it but the car i was jumping off of probably wasnt the best. Any ideas on why i can't cold start. Oil is fully synthetic, fuel pump is about a year old, brand new battery i picked up before i drove it home. Haven't checked the relay and didnt listen for the fuel pump. The engine is leaking oil like you'd expect a car from the 90s but its not a whole bunch. Also didnt check my oil pressure just because i had to get to work, als bone stock except my exhaust. Will be going home on lunch break to try to start it with the sun out since everytime I've successfully started it has been afternoon-evening time. Also if someone doesn't mind answering if i keed to get a can of engine starter, where the heck do i spray it at. Thanks in advanced. This is my first vette
I would check codes first, lots of reason for the car not starting. Don't use starter fluid it's not going to tell you anything.
https://tech.corvettecentral.com/201...trouble-codes/
Congrats! with your new ownership. Last year of the C4.
Adding new tools to your box. Will make EFI diagnosis much more efficient.
As suggested codes are rule number 1 must have info.
Knowing fuel pressure is mandatory.
Typically this points to the CTS coolant temp sense.
It would be ideal stopping at a chain parts store like AutoZone. read code/s, loaner, rent FP gauge.
Keep us posted with any codes discoveries.
I'm confused by the statement it cranks but doesn't turn over. Is it actually turning the crankshaft as in spinning complete revolutions over and over or does the starter try to turn it then go dead. If it's the later I would check the battery,cables,and starter. If it's the first you'll need a lot more diagnostics help. Just my two cents.
The following 2 users liked this post by ZumpC4:
CorvetteRules (09-25-2022),
IHBD (09-25-2022)
so dont use starter fluid or give it a try? if i can use it just to get it going so i can get to a shop im fine with that. But lets say i use the starter fluid and it works. Now where should i look from there? Sensore maybe
You originally bounced around. With the battery detail. Had to read between details.
Your problem is a only.. a intermittent NO start. Cold. correct?
Save yourself time and aggravation.
***Click on bac22's link to retrieve codes.
Post the codes found.
OE optis are very reliable.
Unless. Original owner purchased a recent replacement. The modern aftermarket Opti's. Are horrible.
With that said. Post codes instead of. As of now someones rumor. Fuel pressure reading would be handy. Next determine if you actually have spark.
As ZumpC4 stated, if it starts with starter fluid it would give you a clue. Possibly your not getting fuel. Your next step is if it starts with starter fluid would be connecting fuel pressure gauge to see fuel pressure when key is turned to start and pressure while you crank.
NO. Fluid. Just as his advise.
no matter how old or new the vehicle this still applies, when you have fuel air and spark in the right quantity and at the right time it will run. When they don't start checking those things as one is missing or off ratio. When new enough to have a computer, always read codes first. No need doing extra work when i will tell you if issues are there. A fuel pressure gauge, good volt/ohm meter and something to check spark (though I still use a screwdriver in the plug wire myself) will take you a long way. Take your time and enjoy the process. I would guess that the majority of people on this forum enjoy the tinker process.
Possible. Depending on mileage very unlikely.
As far as the modern optis. With cheap components.
I can vouch. I tried a jegs opti as a last resort. It failed approx 6 months. Finding a "genuine" opti is a egg hunt. Pulling from a boneyard sitting around for years / decades. Is like winning the lottery.
You can inspect/ diagnose. validating if the PCM is recieving the signal. Before blaming the opti
What codes have you found??
Well. Unfortunately electronics. Does not have a experation date.. with that said 171k or slightly below is proof the opti is reliable. And have to admit superceded it's task.
THE 383 admiral (09-25-2022)
I have an adjustable/ digital timing light from Innova. Works fantastic on LS style coil packs. Few months after driving my new purchase C4. 4 coils failed within weeks of each other. simply crazy.
Keep us posted with your codes.
