Help Identifying this Part
Hello everyone, I'm new to the corvette platform and I'm having trouble identifying this part. It is an L98 and the piece is pointed out by the blue arrow. Thank you so much and I appreciate your help & time.
The part in question is pointed out by the blue arrow.
Received 1,597 Likes
Coolant temperature sensor.
kenmohr (05-19-2022)
This is correct and the 'image' in post #2 is incorrect. Post 3 has a correct description also but shouldn't have been so quick to agree after seeing the image in post #2.
A GM 14043276 or an after-market equivalent would be correct and you'll also need a new connector to use the OE. There are many after-market equivalents.
A search of eBay using the 14043276 will get you images of the correct and also should show a correct connector. Does your car actually have a auxiliary cooling fan forward of the radiator/condenser module?
The correct switch and the connector should be available for a 'local' purchase I'd think.
Do you have the FSM for what ever year your Corvette is? I have all years available and offer with it a very good GM SPO Parts Catalog. Mine is I believe a better option that the CD/DVD offerings most anywhere. Drop me an email or a PM if you're interested.
In the FSM there's a complete section for a 'new' owner to use and actually ID various components of the car.
ToniJ1960 (05-18-2022)
