How is this piece of carpet held in place?
Item #12, how is it held in place, glue or some other way? I have a 93 Convertible and there is a wiring harness under neath this piece of carpet I need to replace and I need to know how the carpet is held in place. Thanks!
If I'm looking at it correctly, that's the back piece that goes behind the seats. I had my carpet completely out about 5 years ago. If I remember correctly, it's formed to fit and tucks under the floor carpet. There's no adhesive, you'd probably be good to remove the seats so you can have decent access.
SloJo (11-28-2021)
SloJo (11-28-2021)
but it doesn't show where it came from. Also, how was the carpet affixed to the panel, glue, or something else?
The carpet is not fixed to the back panel. It is draped over it. It appears to be somewhat formed, and mine ends about 1" on top of the floor carpet. The top portion that drapes over the top of the panel is held in place by the screwed down frame of the storage doors. I believe the harness goes underneath the console frame but just cant remember specifically. On a 93 the carpet on the side of the console is glued in place so the harness cannot run underneath it.
Thanks, jrobin1, that's what I need to know!! Doctor Don, who is fixing my radio says I can replace that harness with removing any carpet
or the console. I don't see how I can do that but he says he's done it. When I get everything back from him I'm going to call him and have
him guide me thru this process. I will post the results on here for anyone else who may have to do this.
